Wichers123
Mines still a 4.6
Stock pi heads...yes it will run slightly better, but good luck touching 300rwhp. The most hp I've seen from a stock 2v headed 5.4l swap was 317rwhp and this guy had ported heads, long tubes, all the bolt ons....etc. How ever!!!! You keep your rear gears in the 3.08-3.27 area; you will love the cars drivability torque! Idle torque to 4000rpm is down right stupid!!!! I say this and I have stock 2.73gears with dragradials. FUN FUN FUN!! Installing a n/a 2v 5.4l is really not worth it if you are looking for track times, but street fun!!!
A gear ratio of 3.55 or greater puts the engine out of its best power range and you basicly rely on an rpm range of its hp output....that equals not good. Now if you were to go 4v...totally opposite. The heads would let the engine breath! That being said, keep your rear gear to were the engines output is the greatest. In our 2v case scenario....numerically low gear ratio and learning how to drive in the lower rpm's. I'm watching your build and will be here if you have questions.
Trick flow heads with high compression puts the rwhp around 375. Someone supposedly touched 420rwhp but the story line was sketchy.
If your plans are to s/c later then your gears will be fine. The 2v heads are the hp limit n/a but s/c will extend the rpm range, but then again you will some find that traction will be absolutely impossible. Yes traction will be a problem!
