96 Purple Pony
Staff member
Lawrenceburg Kentucky
When the dyno started reading at 2000rpm my rwtq was 280 (100lbs more over any 4.6l) and climbed to 330rwqt and flat lined all the way to 5000rpm........so yea......you will love the torque. And that was npi heads with comp 274 cams. The hp though was a sad 280rwhp. I don't know of anyone with dyno results of a swapped npi 5.4l.
sk1tskat
sk1tskat
Houston
Oh so could I assume mine will have better gains for obvious reason of Pi heads
Sent from my iPhone using Tapatalk 5.0
sk1tskat
sk1tskat
Houston
She was dropped off at the shop today :D year down begins tomorrow...purchased a new clutch kit for the billet cobra flywheel.
sk1tskat
sk1tskat
Houston
4.6 is about ready to be pulled
sk1tskat
sk1tskat
Houston
Always good to have access to a lift
Cobra aluminum flywheel with a resurfaced grip disc installed
Staff member
Stock pi heads...yes it will run slightly better, but good luck touching 300rwhp. The most hp I've seen from a stock 2v headed 5.4l swap was 317rwhp and this guy had ported heads, long tubes, all the bolt ons....etc. How ever!!!! You keep your rear gears in the 3.08-3.27 area; you will love the cars drivability torque! Idle torque to 4000rpm is down right stupid!!!! I say this and I have stock 2.73gears with dragradials. FUN FUN FUN!! Installing a n/a 2v 5.4l is really not worth it if you are looking for track times, but street fun!!!
A gear ratio of 3.55 or greater puts the engine out of its best power range and you basicly rely on an rpm range of its hp output....that equals not good. Now if you were to go 4v...totally opposite. The heads would let the engine breath! That being said, keep your rear gear to were the engines output is the greatest. In our 2v case scenario....numerically low gear ratio and learning how to drive in the lower rpm's. I'm watching your build and will be here if you have questions.
sk1tskat
sk1tskat
Houston
Well I know the 300rwhp at the end of the day won't be a problem as I will be doing a supercharger set up but...that's disappointing about the gears as I have 3:55 right now ill just have to wait and see how it feels.
sk1tskat
sk1tskat
Houston
I have another rear end with some stock gears unsure of which but I could easily swap out if I do have problems.
Staff member
Trick flow heads with high compression puts the rwhp around 375. Someone supposedly touched 420rwhp but the story line was sketchy.
If your plans are to s/c later then your gears will be fine. The 2v heads are the hp limit n/a but s/c will extend the rpm range, but then again you will some find that traction will be absolutely impossible. Yes traction will be a problem!
sk1tskat
sk1tskat
Houston
I've got a set of dr's
sk1tskat
sk1tskat
Houston
5.4 is now in
K member spacers are in now to work out the exhaust
sk1tskat
sk1tskat
Houston
Fired her up today sounds really good have a few adjustments to make and will get a video :D
Staff member
Don't expect much untill the tune! I couldnt even get the tires to spin popping the clutch. I thought oh man what have I done...this is a turd! But then I had it tuned!
