Gratuitous engine bay picture
What is the right fix? If you dont fool the sensor, can you set it differently with a computer?
What ya need more gear for lol?2500 in 5th. its fun no doubt about it i just need more gear. more gear and some better gas mileage for the moment are my only issues with 410s. no joke 65mph vs 70mph is about 150rpm difference. 80mph is about 3k. ive gone over 100mph (maybe 110?) and it was under 4500rpm
I wonder how much a stb would improve my convertible.
Sent from my SM-G920V using Tapatalk
Also this settup does not fit under my factory strut tower bar, i had to push down as hard as I could to get the bolts to line up. It buckled the rubber coupling between the throttle body and the JLT intake but I guess that will have to do. I need it because the car is a convertible. Do any of the aftermarket ones offer more clearance?
Clean all the sensors, replace as necessary, ensure there are zero vacuum leaks, reset the idle by disconnecting the battery for 30 mins, then starting the car and letting it sort itself out.
The car wants to run correctly. All of those things help it.
The restrictor plate covers up where one of those things is failing. I made a restrictor plate too, but I am not fooling myself, the hanging idle problem is from a huge vac leak between my lower intake and the block.
I wish I was that cool lol.Custom fab one around the tb
And still make power with a pi intake?Just to put it out there, you can rev the 2v higher than 6200.
