About to throw this TB/plenum setup in the trash
white95
Apex Junky
Prairieville, LA
Gratuitous engine bay picture
DKblue98GT
Have you cleaned out the IAC?
I put a70mm SR TB/Plenum combo on my GT a few years ago and had bad hanging idle. I made a restrictor plate and it didn't work very well. I cleaned the IAC with MAF cleaner and it fixed the problem.
Worth at shot...
g36 monkey
Orlando, Fl
What is the right fix? If you dont fool the sensor, can you set it differently with a computer?
Clean all the sensors, replace as necessary, ensure there are zero vacuum leaks, reset the idle by disconnecting the battery for 30 mins, then starting the car and letting it sort itself out.
The car wants to run correctly. All of those things help it.
The restrictor plate covers up where one of those things is failing. I made a restrictor plate too, but I am not fooling myself, the hanging idle problem is from a huge vac leak between my lower intake and the block.
Tally_4.6
More well known than you
Clermont, Fl
Def. missed the amazing 2.73 gas mileage for the first trip or two to Tally, then swapped rear ends and that went out the window.
96Mystic1189
96Mystic1189
Mechanicsville, MD
2500 in 5th. its fun no doubt about it i just need more gear. more gear and some better gas mileage for the moment are my only issues with 410s. no joke 65mph vs 70mph is about 150rpm difference. 80mph is about 3k. ive gone over 100mph (maybe 110?) and it was under 4500rpm
What ya need more gear for lol?
96Mystic1189
96Mystic1189
Mechanicsville, MD
Also this settup does not fit under my factory strut tower bar, i had to push down as hard as I could to get the bolts to line up. It buckled the rubber coupling between the throttle body and the JLT intake but I guess that will have to do. I need it because the car is a convertible. Do any of the aftermarket ones offer more clearance?
Nighttrain
Atglen pennsylvania
Custom fab one around the tb
Nighttrain
Atglen pennsylvania
Gotcha....didnt think of a vacuum leak dohh
96Mystic1189
96Mystic1189
Mechanicsville, MD
Hey guys question, If the plenum bolts lined up through the plenum gasket, that means it has to be on correctly right? Isn't there a tab that would hold it up if it wasn't sitting just right? The C&L plenum does not fit the curves of the gasket perfectly making it look out of place but I think its just the casting of the plenum.
96Mystic1189
96Mystic1189
Mechanicsville, MD
Ok I thought this was fixed but it still kind of sucks. Its a lot better than it was but still hangs for a long time when the clutch is pressed. It seems to be worse once the car has heated up, but that could be in my head. Who knows, so I guess ill keep my windows up so people wont see me while I burn my clutch up.
