Adjustible.
looks like they come with a special tool to adjust them. I have the Illuminas, they just adjust at the top with a small flat head screw driver.
Win
Kennesaw, Ga
ReplicaR
or, since you are spending that much anyway, might as well do this
http://cgi.ebay.com/ebaymotors/KONI...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Koni in my opinion are a lot more serious of a damper, and they are easy as hell to adjust as well. They have a dial that can be adjusted from the top using provided knobs. I've been using mine for over 3 years for daily driving and road racing, and I have no complaints about them at all. They also come with lifetime warranty.
Slykin
Tyler, Texas
How would you compare these to Bilstein HD's if you want to change over to coil-overs? As far as I know the Bilsteins are not adjustable, but i've heard some good things about them. They are more expensive though.
Matt94GT
I have tokico illumias, have never adjusted them besides when they were first put on. I also have coilovers and love the setup and feel, they made a big difference IMO.
When looking at shocks/struts I would look to see if they are coil over compatible with MM's coil over kits (the best ones at an affordable price) and go with those. I wish MM made a rear coilover kit for the Illumias but they dont.
ReplicaR
Bilsteins are about on par with the Konis off the shelf. You don't get the adjustability, so they are just still all the time, which is cool for tracking and stuff, but getting annoying quick on the street. The other thing you've mentioned is that Bilsteins are more expensive upfront, but once it's time to revalve for more aggressive spring rates, that's where Bilsteins pay off big time. There are thousands of places that can revalve Bilstein shocks, but Koni has only 3 authorized centers in US. Then there is a price of service. To revalve Koni for more aggressive valving, with a hook up it is 140 dollars a shock. Bilstein is 60 dollars for the same deal pretty much everywhere. I'm thinking that once I go stiffer on my spring from where I am right now, I'll probably sell the Konis and get MM Race valved Bilsteins.
Slykin
Tyler, Texas
Sorry if i'm getting a little off topic here everyone, but I figure this is good information to know if the OP doesn't mind... But exactly is revalving for? I would assume the adjustable struts wouldn't need revalving since they're.. well, adjustable. It seems i'm wrong though. If you could expand on this a little bit? Thanks, this is good info.
ReplicaR
Well, shock is there to control and dampen the movement of the spring. If the shock was not there, the spring would be bouncing uncontrollably, and your wheels would just dribble down the road like a basketball. Now, reason for more aggressive valving is simple. The stiffer the spring, the more force it produces when it moves around. The more force the spring produces, the more aggressive valving is required to control that movement (stiffer shocks). Most off the shelf shocks, even the adjustables are only good for so much force they can control, until they are unable to keep up with the spring, and you end up with wheel hop in the corner. Some are better than others, but you still need something serious once you are getting close to race car spring rates, and off shelf stuff is not cutting it any longer.
Slykin
Tyler, Texas
So you should be fine as long as you aren't going into really stiff spring rates on an adjustable strut? I just haven't figured out if Koni's or Bilstein's the way to go on a daily/auto-xer.
Win
Kennesaw, Ga
If it were me. I would do a Bilstein HD with a Coilover up front. Koni Yellow rear with H&R super race in the rear with a Aftermarket rear LCA.
that's what i plan on going with in the very near future!
ReplicaR
Mismatching shocks is never a good idea. They have different valving systems (Koni is twin tube / Bilstein is mono tube), and they will react differently to force applied. I would not do that, as it just seems counterproductive, unless you can obtain dyno graphs for both of the manufacturers, and verify that they dyno about the same at optimum valving.
I actually ran Super Race spring in the back combined with 275 coil over spring in the front, and it was fairly compliant still. Not bad of a setup honestly.
Win
Kennesaw, Ga
Very true but did you run koni's all around. i am going off everything i have read for a year of researching.
ReplicaR
Koni front and back. Why did you decide on running Bilstein up front? 03 Cobra take offs?
Win
Kennesaw, Ga
03 Cobra take offs and just what i have seen over a year it meshed well with everything. Ya know i could get it on my car and hate it but it's worth a shot.
Jeez, $100 less than Maximum Motorsports.
