Are gears worth it in non pi stangs?
I say it a lot: Gears = best feel-for-money mod there is.
AaRoN
King Post Whore
tRaV_19 said:
gears are around 170 but dont stop there ...get a nice rear cover...get that svo thick one with the stud caps and fill holes i love mine.... then get a trac loc rebuild kit....no sense opening up the rear and leaving the job hanging...
+1
ripper
So you guys think he should get gears??
:D :D :D :D :D ok ill be over there :gtfo:
T
Twista
DropTopPony said:
do it do it,
sell a few of your headlights and catbacks and you can get them.
ROFL, no-one wants the projectors it seems. My smokes are gone though as of tomorrow. :thumb:
Hellion94
FRPP is the only way to go, trust me. Go with them, that's all we have ever used, even in our racecars. Think about it, they're the ones that designed the original gears, the rear ends they go into, the axles they turn, everything. I'd stick with the people that created them in the first place..
W
Wes8398
Did any of you AOD guys have to change shift points with your gears? Or can you go WOT in "D" and shift without hitting the rev limiter? And how easy/hard is it to change this speedo gear? Just pull the guage bezel out and there it is? Or is there more to it?
GDawg
I have the stock option 3.27 gears. Not so sure I want to swap those out. I run out of gear quickly at 3.27. And I plan to build up my bottom end then a 14psi pully and maybe spray to boot. I just can't see going steeper. I already spin through 1st and 2nd.
If I do swap, it will be no more than a 3.55 gear. :pimp2:
Without forced induction I would recommend 3.73 for manuals and 4.10 for autos.
Canaryonvskf’s
