Best replacement starter??
Daryl
SoCal
I did a search on the Forum and came up with a thread from 2017. Anticipated advice therein, but that was 4 years ago. So, thought I’d ask again in case there’s any further information or products out there I should be aware of and/or take into consideration.
Thoughts? Opinions?
Thanks in advance!
joemomma
Sounds like you've narrowed your slow/hard start down to the starter then?
papac0rn
I purchased one last year from pa performance. I see they are now 150 but last year I bought a returned one for $79 including shipping. Seems well built and was plug and play.
Sent from my SM-T830 using Tapatalk
sluggish94
SVE mini starter has worked great for me on my Turbo Mustang.
Stock starter hasn't crapped out on Dirty Money yet but I will probably get a parts store replacement if it does, as those are pretty much up to the task.
Truthfully, a lot of OEM components (new or reconditioned) do really well even in modified applications. (ex: plug wires, ignition coil, 8.8 diff bushings, distributor, steering rack, etc...)
Daryl
Daryl
SoCal
That’s funny, I was looking at both the PA and the SVE.
Hmmm…. decisions, decisions!
Gonna be a PITA to R&R. Damn K-member support is right in the way.
Daryl
Daryl
SoCal
Checked: not long tubes. Headers end just shy of the bell housing
Daryl
Daryl
SoCal
Daryl
Daryl
SoCal
Papa,
Is your motor stock, or a higher compression? I need a starter that’ll turn over my 347 stroker.
My previous project car, a ‘64 Chevy II, had a PowerMaster starter. Worked nicely on a 350 with top end (AFR heads, dual plane intake manifold, EFI)
Daryl
Daryl
SoCal
What gear ratio should I look for with the 347? I’m also hoping I have a standard tooth flywheel (got a new, steel flywheel with the McCloud clutch same time as engine rebuild)
joemomma
Papa,
Totally unrelated, but my first car was a '65 Chevy II. Wish I still had it. Got it when I turned 15 in 1990. Traded a rifle and a 4-wheeler for it as a roller.
Daryl
Daryl
SoCal
Sold it couple years ago to a local guy. Took this pic short time ago when I scoped it outside his workplace (also my favorite brewery) where he’s the Master Brewer. He did the plate. Only pic I have left of it. Wah-waaaaah! And yes, it’s a 4-door. Can’t hardly find a 2-door let alone an affordable one here in Cali.
T's Convertible
