Last year around November I ordered C&L cold air tube, air shield and 76mm mass air meter housing.Since my car is stored in my garage for winter I didn't get in any hurry to install anything but finally got around to it today. I used to have a 73mm C&L mass air meter on the car years ago and switched to a Pro-M because I had always read good things about them in the magazines and on various forums, but when my Pro-M started to throw codes and cause my car to run bad I decided it was time to replace it.
The C&L cold air tube that I bought is very well made and it the fit and installation is very good.The only thing that I had to change from the factory rubber air tube was the IAT sensor.The C&L tube has it relocated from just behind the mass air to in front of the curve that goes into the Throttle Body.All that required was just re-routing the IAT wires which took less than a minute.The air shield that came with the air tube didn't fit well with the air filter that I'm using because of the size of the filter that I'm using which isn't really that big of a deal to me.
After I got everything installed I took the car out for a ride, no more check engine light with the new mass air meter housing and sensor and the car ran great and my idle quality returned to normal.
