car missing driving normally
sn95jones
Arlington, Tx
My car at idle runs fine but started missing after i got off the freeway. I was coming back from lunch and was about to miss my exit so i got on the throttle to catch my.exit. Once i got off i noticed it started missing. Once i got to the light it stopped but when i tool off it started missing again. Whats going on? I got no cel on either.
MustangChris
Aurora, CO
did your plug wires wiggle loose? i had the same problem as you and my wires were loose. one was pretty much completely off the plug.
sn95jones
sn95jones
Arlington, Tx
I'll double check but I don't think they were loose. I got a hot date tonight and would be VERY embarrassing if it misfires on me. Mustang's are her favorite car so it's do or die!
ademily87
CHARLESTON, SC
If she's a mustang lover, and you really wanna get her going, find out what the problem is and don't fix it till after you pick her up and look like a bad ass while you save the day and fix your car!!
Thank me later.
(i know I know, I should write a book similar to the movie "Hitch")
Sent from my ADR6400L using Tapatalk 2
sn95jones
sn95jones
Arlington, Tx
Date went great car ran fine but i noticed it misfires when it warms up. Like i said i think its related to the fuel smell under the.hood.
CC'S95GT
Hampton ,Ga.
Missing when it warm up is a common sympton of the dizzy heading south. Same with the coil too. You can do some testing first though. A coil is fairly cheap and is probably due for replacement anyway.
What is this fuel smell you have now. If you don't have a leak under the hood or back at the tank then most likely the charcol canister is full and is ready for replacement too.
sn95jones
sn95jones
Arlington, Tx
No fuel leaking im betting its the canister. Im almost 90% positive how can i check it? Im just going to replace my coils
CC'S95GT
Hampton ,Ga.
crap! sorry about leading you down the wrong road then. Nothing I suggested applies to you. I assumed your screen name ment you had a 95.
I would think you could ck for codes. you may have one set without having the CEL being on. Could be still ba a coil pack but a code ck should be able to tell you that.
sn95jones
sn95jones
Arlington, Tx
So heres the verdict Ford did a diagnostic free of charge for me and here's what we got.
