Cpotts13
that is a clean ****ing car.
Thanks MC. Glad to have found a clean one. Most are beat to shit or have tons of miles..
yes they are... the 3vs tend to have rough lives.
Just so I'm clear mach 1s are dohc 4v? I never knew this but then again I'm a die hard pushrod man. Gorgeous car keep more pics coming
Brought to you from a a land far far far very far veryy very far away
Another cheap and also free upgrade is to either degree the stock cams,or get 98 cobra intake cams.Just by lining up the dot to dot on stock exhaust cams and 98 cobra intake cam you will gain 20-25 hp to the wheels and if your mechanically inclined the cams will set you back as little as $150 plus a few extra parts.
But you dont suggest to degree the cobra intake/stock exhaust cam.... OOOOOODDDDDDDDDDDDDDDDDD !?!?!?!?! Any came, ANY time its installed/removed or repalced, should be (re)degreed.
I'm glad to hear you had an easy time installing that mid pipe. My UPR offroad-X fit like shit and had to be custom welded to fit.
Alright y'all. Little update... I have been getting a check engine light frequently (I keep resetting it), so I got ahold of a code reader and it says that all 4 o2 sensors are faulty, well that's what's throwing the codes anyways... So tell me... I believe I may have mixes up the o2 sensors when installing my off road x pipe.. Is there a difference? I keep reading different things... Is there upstream vs downstream?? Thanks..
