Deeplist's Project "Ivory Snake"
Status
Not open for further replies.
DeepList
DeepList
Auburn, IN
I found a nice little area at the warehouse to set up shop. Today, I completed bringing over all the parts from home. On Thursday, we'll be bringing the car over on a trailer. There's just so much more "leg room" over here than what I have in the garage at home. I'll be getting some kind of work bench set up shortly as well as some florescent lighting. The yellow plate in the photo is removable and there's a 4 foot pit under there. I'm going to cut the removable section to be a bit larger, and then I can use the pit to work on stuff under the car (for the time being until I get a lift) without the PITA of jacking it up/down constantly.
03DSGGT
SN95 Supporting Member
Akron, Ohio
Im anxious to see you get back to working on this...you don't see too many New Edge restoration threads let alone New Edge Cobras....
DeepList
DeepList
Auburn, IN
None... The guy that was supposed to help me get the car over to the warehouse with his trailer flaked out. Besides, it's about 30 degrees in the warehouse now and there's no way I can heat that place efficiently with how high the ceilings are. The white car is sitting at home in the garage and will probably stay there at least until next spring. "Life" happened this summer. I'm ashamed to admit that I only had the red car out 2 or 3 times the entire season as well. :deeplist:
DeepList
DeepList
Auburn, IN
Everything is still sitting at the warehouse in a million pieces. The indoor temp there is approx 15 degrees F and the ceiling height is > 30 ft... therefore nothing will be happening until spring because the cost to heat that place is too high, even for me and I can't function in those temps.
However, something I have been contemplating, or at least tossing around, is the possibility of selling off the cobra shell as a roller and still building the 4v as planned, BUT putting it in the 08 vic instead... interesting twist for this project, or no ???
How many people build a 4v and put it in a mustang? Lots.
How many people build a 4v and put it in a cop car? Not many.
ElrodKTPQ_89
Crossett, AR
DOOOOOO ITTTTTTTT!!! Think I posted a few pics in one of your threads of the one I saw at the Power Tour a few years ago. That was a cool car!
DeepList
DeepList
Auburn, IN
Just finished doing an 03 cobra engine in a 04 marauder. Car is very fun to drive and rides awesome
How did it fit in the engine bay? Did you have to make any modifications? Exhaust? I'm worried about the brake booster.
DeepList
DeepList
Auburn, IN
If I went this route, it would be completely decked out. I have the brush guard for the front, all the lights, window bars, prisoner partition, center console... everything.
rtusnake
Lincoln, AL
If your just doing a na 4v it should drop right in. I'm not sure if the brake booster is different in the crown vics or not. I had to notch and box the frame to clear the alternator for the cobra. I'm using kooks longtubes made for the marauder and clears everything fine.
DeepList
DeepList
Auburn, IN
Good. I'm pretty certain it's in the exact same spot.
Very tempting...
DeepList
DeepList
Auburn, IN
I gotcha an upper marauder lid for a dohc C head intake. Or better known as a cobra lower marauder upper
Any advantages over the cobra intake? I bought this complete setup with 0 miles on it specifically for this project.
Status
