Explorer 302 block questions
forkliftfixr
As some of you know I got that deal on the complete 96 Explorer 302. Someone mentioned it being a "sportsman" block..... What exactly does that mean? Also does the "XXX" casting letters by the lifter valley mean anything? My final question... Since the 96 Explorer block has an external oil coller mounted where the filter would be on our cars, I removed that to only find that there is no way to install the filter without that. Does anyone know if there is a filter relocating kit available? I did a google search and was only able to find relocating kits for the 6 cylinder. By looking at the engine bay, I am thinking if I install this block in there and use that oil cooler setup that it will not fit. Any suggestions?
If you dont know what I am talking about, let me know and I will post a photo.
F
forkliftfixr
Here is a photo of the external oil cooler on the 96 Explorer block, if you think about where the oil filter is located on our cars, you will see that this piece would possibly hit the stabilizer bar. Yes, this is stock on the Explorer and is hooked to the water pump.
This photo shows the cooler removed and as you can see there is no threads to put the filter onto because the cooler is held on by an internally threaded bolt.
birel21y
the oil cooler will work. i did this swap with a 1990 gt, 1995, and 1996.
Slow95Cobra
you can probably unscrew the bung that is there, go to a dealership and buy a filter bung for a GT. i would have to look at one to know for sure, but im sure it unscrews and a threaded version goes in.
LAFENATU
It is not a sportsman block. It is a regular stock production 302 block.
Sportsman Block is ONLY available through FRPP.
