F1atlander's 94 357w 74mm
F1atlander
F1atlander
Kennesaw, GA
Working on the engine bay skins.
Some pics of the new parts.
Solid motor mounts
A1000 pump
80mm TB, 60lb injectors, blowtru meter
AEM wide band
F1atlander
F1atlander
Kennesaw, GA
Track wheels
Headers to start the hot side
Anderson PMS 4 w/ map sensor
Still working on cutting the k member out where someone welded it to the frame.
Lots more welding, grinding, and sanding to do.
evilcw311
Most Evil Member!
Louisville, KY
uuuuuuhhhhhhhhhhh.........was just getting to the good stuff and i see all the pics have been deleted!!!!!!
TEASE!!!!!!! lol
good start to the build, now just get the pics back up where we can see them!!! :tongue3:
97stanger
very very cool build. Car will be an animal when its done. What will you be doing for fuel?
Steven
SC
A lot of engine builders say to not reuse the spider setup out of an actual roller block in a non roller block. The oiling passages are different therefore it often starves lifters. That is the rumor anyway. Looks good though, should be retarded fast.
BLOWN 95GT
Alabama
Your build is very close to what I just did with mine but I used a custom built 76mm.
SUBSCRIBED!
F1atlander
F1atlander
Kennesaw, GA
Yeah..... thats not just a rumor. I returned the stock style roller lifters and will be picking u retrofit rollers.
F1atlander
F1atlander
Kennesaw, GA
engine bay progress...
also picked up a Tial 44mm WG and Vibrant 3.5" intercooler. Waiting on kmember hardware then should start coming together.
F1atlander
F1atlander
Kennesaw, GA
traded my coupe for some parts...
chris alston fab 9 rearend, 40 spline axles, moser center, 4.56 gear, narrowed an additional 3"
alumastar 2.0's 15x3.5 and 15x10s
more pics of the wheels, tires, powerglide, and converter coming soon.
mikey94gt
sick build. gonna be interesting to see how that large frame turbo works. love the engine bay work, smooth/hidden wires is the way to go!
F1atlander
F1atlander
Kennesaw, GA
x over done and bolted the t6 turbo on the t4 flange just for a pic. still going to have to modify the passenger side header because of the wastegate location.
Adeptus923
