February 2014 - ROTM - Voting Thread
Status
Not open for further replies.
You remember The Rubble in the Jungle....
Now its time for The Rampage on the.... something that rhymes with "rampage."
The staff selected a number of race-trim cars to nominate in this month. Not *every* race-ready car was chosen. One of my favs, that's yellow, is not here. But that's okay. We had to narrow it down and here are only a few of what the site has to offer!
Take a look. Drool for a while. Take notes. And don't forget to vote! :-D
Shifty Powers
Where the wild goose grows
MadStang
2013 SCCA-SCNAX December Championship Winner (Street Modified)
Engine: (388rwhp/388rwtq N/A)
MMR 600 Short Block
MHS Stage 3 Ported Heads
MHS Stage 4.5 Bullet Cams
Steeda Underdrive Pullies
Accufab Plenum
Roush 75mm Throttle Body
JLT Ram Air Intake
Port Matched OEM Intake Manifold
MMR-Moroso Oil/Air Separator
EGR Delete
PCV Delete
Moroso Coolant Overflow
Odyssey PC-680 Battery w/ aluminum mount
FRPP 42# Injectors
90mm Lightning MAF
2004 Terminator Fuel Tank w/ Pumps
Mac Longtube Headers
Mac Catted H-Pipe
Dynomax Super Turbo Side Exit Exhaust
Fidanza Aluminum Flywheel
Exedy Mach 500 Clutch
Steeda Firewall Adjuster
Steeda Adjustable Clutch Cable
Steeda Quick Release Quadrant
FRPP Aluminum Driveshaft
FRPP 3.73 Gears
e85 Tune
Chassis & Suspension:
Roush-Bilstein Shocks & Struts
Maximum Motorsports Forward Offset A-Arms
Maximum Motorsports Front Coilovers (375# Springs)
Maximum Motorsports C/C Plates
Maximum Motorsports Strut Tower Brace
Custom Front End Alignment for Autocross
2000 Cobra R Steering Rack
Maximum Motorsports Solid Steering Rack Bushings
Maximum Motorsports Bumpsteer Kit (Cycled Bumpsteer out)
Maximum Motorsports 4-Point Roll Bar
Roush Subframe Connectors (Welded In and tied to roll bar)
Maximum Motorsports Rear Coilovers (275# Springs)
Fays 2 Watts Link
BTM AutoSport Offset 3-Link
Wild Rides Battle Box Reinforcements
H&R 1" Hubcentric Rear Wheel Spacer
Roush Tubular Rear Lower Control Arms
Roush Rear Sway Bar
Roush Pinion Snubber
Roush-PBR 13" Front Brake Caliper Kit
Raybestos R-300 Brake Rotors
Porterfield R4-S Brake Pads
Speed Bleeder Kit
Interior:
Corbeau Style Reclining Race Seats w/ custom seat mounts
G-Force 6-Point Harness
Roush Gauge Cluster with custom mounted Autometer Oil Pressure Gauge in Cluster
Home Made Progressive Shift Light
Florida 5.0 Radio Delete Panels
Home Made HVAC Delete Panel w/ AFR Gauge Mount
Home Made Passenger Airbag Delete
MOMO Steering Hub
NRG Quick Release v2.0
OMP od/1990/nn Steering Wheel
PLX DM-5 Wideband Gauge
Roush Short Throw Shifter
Gutted Dash, Doors, and Trunk
Removed Sound Deadening, insulation, etc.
Exterior:
Roush Stage 3 Front Bumper
BTM AutoSport Front Splitter
Steeda Q400 Hood
Moroso Hoods Pins
Roush Side Skirts
Roush Rear Valances
Roush Side Exit Exhaust System
Roush-Yates (Crawford Composites) COT Carbon Fiber Wing
Agent 47 Vortex Generators
FTR Tow Hook
Wicked Motorsports Rear Diffuser
SCF Carbon Fiber Wiper Cowl
Headlight Intake
HIDmasters 6000k Foglight Kit
Mirrored Finish Radiator Panel
2000 Cobra R 18x9.5 Wheels
-285/30/18 BF Goodrich R1's
mcglsr2
Thanks for the nomination! Pics first:
What's Been Done
These are the things I have personally done to the car since buying it in 2011:
Engine
  • Stock 5.0
  • ZAP 3 core aluminum radiator with balanced 180* thermostat
  • BBK 255 LPH fuel pump
  • Kirban adjustable FPR
Exhaust
  • BBK off-road H pipe
  • Dynomax Super Turbo mufflers
Driveline
  • Freshly rebuilt T-5
  • RAM HDX clutch
  • RAM billet aluminum flywheel
  • Ford Racing aluminum driveshaft
  • Ford Racing T-2 Torsen differential
  • Ford Racing 3.55 gears
  • New Moser axles
  • Poly engine and trans mounts
  • Hurst Black Billet Plus shifter
  • MM clutch adjuster and quadrant
Interior
  • Momo steering wheel
  • Airbag deletes
  • Auto Meter gauge cluster with LED Auto Meter gauges
  • Custom dash pod with LED Auto Meter oil temp gauge and idiot lights
  • Corbeau Forza for the driver seat, with sub belt cutout and double locking slider bracket
  • Corbeau A4 for the passenger, with sub belt cutout and double locking slider bracket
  • Rear seat delete
  • Billet Mach pedals
  • Orange TPMS monitor
  • Ecliptech progressive shift light
  • Toggle switch that turns the cooling fan on high
  • Zeitronix Wideband AFR with LCD display
Brakes
  • Front: Cobra rotors and calipers
  • Rear: Cobra rotors and bracket kit
  • Braided SS brake lines
  • Agent 47 front brake duct kit, feed is where the fog lights used to be
  • Hawk HP+ pads all the way around
  • New parking brake cables
Suspension
  • H&R Race springs
  • Tokico HP Blue struts/shocks
  • Poly front sway bar mounts
  • Poly front sway bar end links
  • MM Caster/Camber plates
  • MM Extreme Duty rear lower control arms
Steering
  • MM solid aluminum steering rack bushing
  • MM solid steering shaft
Wheels
  • Enkei RPF1 17 x 9 front and rear
  • Orange TPMS sensors
Body
  • Tow strap installed in front bumper
  • Tow strap installed in rear bumper
What's Being Done
These are things that I am currently working on (and why the last pic is the car up on jack stands in the garage) - a good portion of these are already completed but I haven't put the car back on the ground yet:
Brakes
  • New rotors and pads (HP+ pads)
  • Replacement hose for the brake duct kit since I tore through the first set
Interior
  • Replacement wideband O2 sensor
Suspension
  • MM Coilover kit and Koni Single Adjustable fronts, 375# springs
  • MM Coilover kit and Koni Single Adjustable rears, 225# springs
  • MM panhard bar
  • MM Racing rear upper shock mounts
  • MM non-offset front lower control arms
  • New tie rods/ball joints
What's About to Be Done
These items are next up on the list as soon as I finish the current job:
Engine
  • Edelbrock Performer aluminum cylinder heads, 1.90" intake
  • Lunati Voodoo 221/229 cam
  • Lunati 1.6 stud mount rocker arms
  • Ford Racing Cobra Intake (crappy Chinese-made one)
  • BBK 70mm throttle body
  • BBK 76mm MAF
  • Ford Racing 24# injectors
  • BAMA custom tune
Exhaust
  • BBK 1-5/8" longtube headers
  • BBK short off-road X pipe
Driveline
  • MGW shifter with race handle, and MGW gripper shift knob
Interior
  • New black carpet
  • Paint dash and interior panels black
  • Scott Rod black aluminum door panels
  • Scott Rod black aluminum rear seat delete kit
  • MM 4-point roll bar
  • 5-point racing harnesses for driver and passenger seat
  • Custom made aluminum center console with cup holders that actually work
Body
  • Plasti-dip entire car matte white
  • Vinyl matte black center stripe and some accent stripes
  • Matte black car numbers (534)
My goal with the car is to enter NASA Time Trial at the end of this year!
Thanks everyone for the consideration, good luck to the other participants, and if you are interested in reading/seeing more on this car check out my build thread here. Thanks again!
-Scott
MustangMatt96GT
Racecar project. On a budget. SFI 25.3 built in my garage. Legal to 6.50's at 3600 lbs. Getting a 5.3 ls with a GT55-18R turbo in a 88 mm, ill be tuning it with a holley dominator efi and using e85 and an air to water intercooler. Everything on the car is constructed by me, piping, carpet, cage, panels, fuel and water cell, plumbing, everything.... Suspension is custom built by me. Will be a street car that can drive to and from the race track, go mid 8s and drive home.
Started a business based on this, people have seen my work and I have been doing cage and chassis work on the side lately.
m@nu
Hi everyone thanks for the nomination
so being the off season here in canada it make it pretty hard for me to give you updated pictures espacially since my car is in a small non heated place .
I have been working on it still
a lot again is being done to the car this year ... suspension wise again
i have a lot of parts to install
upr torque box reinforcement plates
eurethane bushing for rear control arms
kenny brown front sway bar
dmv front lca
av fab front knucle (made by me and my mechanic)
qa1 sway bar links
bc racing front coilover
rear wheels spacer
roof wing
subframe connectors
stedda outer rca tie rods
new oem inner tie rods
lightweight aluminium wheel lugs
eurethane swaybar bushing
i took out the inner plastic rack stopper to get more travel out of my rack
4 new tires
bolt kit for the rear lca
new rear lower lca
i also this year wanna work on my rear end to get more travel out of the suspension by probably relocating the top of the strut mount and raising the car just a bit
i would love to change my wheels probably to get some te37 replica .. and also an half cage but i just bought a house so money will go somewhere else
obviously i got a lot of maintenance to do on the car
a major bolt check
change the oil in the diff
my seat bracket got bent when i went offroad during an event so i gotta fix that
clean the interior of the car because of that off road trip :D
oil change for the motor ( dhu)
spark plug change
that is pretty much whats going on with me and my car
this i what i look like on a normal race weekend :)
my goal with the car this year .... put a tire mark im my friends door or at least bumping him :)
and obviously drive as much as i can !
manu
RichV
CAR: 1994 Mustang GT OnyX Black
PURPOSE: NASA's Camaro Mustang Challenge
STREET LEGAL: Yea Right!
INTERIOR: None. MOMO wheel. Sparco Driver Seat, intact dash per CMC rules, stock cluster, Autometer 2 5/8" ProComp Water Temp and Oil Pressure, Firecharger 2.3L dual nozzle fire suppression system.
MOTOR: Roller 302 shortblock, GT40p heads, SN GT40 SVO intake, BBK shorty headers, BBK u/d pulleys, BBK intake tube with cone filter.
DYNO: detuned to 266HP and 297Tq on DynoJet, made 273/307 at 14* timing
DRIVETRAIN: Stock T5, King Cobra clutch, FMS aluminum driveshaft, stock 28 spline 8.8 with 3:73 gears.
BRAKES: F- revolution brake 13" Wilwood 4 piston upgrade with HAWK DCT-70 pads. R- OE 11.65" Cobra setup with HAWK Blues. Earl's braided lines (all 5). Brake cooler ducting from airdam. Disconnected ABS.
SUSPENSION: F- Koni SA yellows and H&R Race springs, MM CC plates. R- Bilstein HD with MM 415lb race spring, MM PHB, stock UCA, J&M LCA.
CHASSIS: 6 point road race cage by Hankville Hotrods with NASCAR bars and x-brace. Global west front LCA bushings offset, MM lower brace, unknown upper strut brace.
WHEELS/TIRES: MB Motorsport 17"x9" Competitions and OE '03 Cobra 17"x9" with TOYO RA1 tires (class tire), 1.25" spacers in back.
BODY: Stock. Decals by RatRacingGraphics.
The car is built to CMC class rules.
RichV
CO
Methinks I brought a pencil to a gunfight!
Thanks for letting me take part!
Musturd
Thanks for for saying that Chris I would have had to decline anyways , I don't want to be nominated again until the combos complete ... It will be worth the wait come spring . I casted my vote
understandable.
There were a few others we wanted to toss in, too, but we figured we can do round 2 in a few more months... :p
Orange 94
Alberta Canada
When its done, you're gonna be alberta bound right?
Need to get the banana and the orange together.
btw, wont be in leth for street machine weekend this year.
Musturd
Yea ear im coming your way and photo shoot is definitely much needed Canadian shoot yellow and orange will be sick
mcglsr2
Orlando
Thanks for the nomination, and good luck everyone! There are some sweet rides here :)
Status
robtalbott
