So, a little update. First picture I took by mistake, but I thought I would go ahead and post it because it's a nice shot of my side scoops. I love my side scoops. So:
Anyhow, finally got around to installing the Maximum Motorsports steering shaft. I will give a quick "walk through" just so people know what they are getting into.
Instructions say to do the job on jack stands, I personally disagree. You want to limit the movement of the tires as much as possible once steering is disengaged. To do so, I drove up on my ramps. Obviously if you have a drive on lift, life would be easier. I hadn't used these bad boys in a while, so it was nice to break them out.
The next step is also pretty important. Stabilize the steering wheel. If you are at a shop you might have one of those fancy tools to do so. If not, I show you how to do it as a normal person with regular garage tools.
Once steering is disengaged, the steering wheel has the ability to spin, if it spins too much, you could sever the wires in the clock spring, which would make for a bad day. Taking 2 minutes to secure the wheel can prevent that.
I do not have pictures of the removal. Instructions are not exactly super useful on this portion either, they basically say, remove the shaft.
There is a bolt on the steering rack that pinches the end of the shaft. Remove this bolt and use your big boy hands to separate the shaft from the rack.
Under the dash, remove the pinch bolt on the steering shaft closest to the firewall. Then remove the shaft from the column. Then you will need to slide the shaft out of the firewall and figure out how to maneuver it out of the car. Luckily, I have tubular front suspension so it glided right out.
Below I have a pic of the old shaft with the new one side by side. Bear in mind I painted the shaft prior to installation. It is bare metal, without paint it will get a lot of surface rust. Essentially, collapse the ends halfway on either side, and tape the ends approximately 1" from the end then paint.
The big problem with this is the rubber.
The next step is to slip off this plastic bushing and the rubber dust boot from the
new shaft. Be very careful, the plastic piece is no longer available. If you
damage it, you will have to hit the junk yard. The plastic sleeve I found
to come off very easily, while the dust boot took a bit more effort, probably
because it was painted over per the instructions provided.
Clean the area on the new shaft where the plastic sleeve will slide onto, as well as the plastic sleeve. I used rubbing alcohol and a paper towel to clean both. I did not want to risk using a more aggressive solvent on the plastic sleeve because of its unavailability.
The next picture shows the area where the plastic sleeve will slip over. As I mentioned earlier, you need to remove the rubber dust boot before you can put the new sleeve on. In this picture that boot is not removed. Do not follow by example. Do as I say! If you do not remove the boot now, you will have a lot of headache on the next step.
The next step is arguably the most time consuming and messiest part of the install. You will need to cover the shaft where the plastic sleeve sits in black RTV silicone. This sleeve fits into a bushing in the firewall, by sealing this area you are preventing noise and fumes from entering the cabin.
The area of focus is the welded bead and approximately 2 inches up the shaft. See the picture for an example. I used an entire small tube of silicone. I find it easier to apply more then remove as necessary to get a good seal. The instructions say to focus more on the flat areas of the shaft because the rounded edges seal quite well with the sleeve.
Once you have applied the silicone, go ahead and seat the sleeve. Then proceed by smoothing the silicone out, making sure to push into the sleeve a bit to seal up any air holes. Make sure to do so at both ends. Do your best to fill all the gaps with silicone.
If you manage to make it look pretty, my hat is off to you. Mine came out ugly as sin, but I know it is sealed!
Then you just let the shaft sit for about an hour before you start handling it. The install is fairly simple. Remove the new pinch bolt from the steering rack side of the shaft. Prior to attempting the install, I recommend collapsing and extending both ends a few times, just in case they got a little bound up from sitting for a while. This will be easier while outside of the car than underneath.
Go ahead and install the shaft onto the steering rack and slide it into position. Make sure the shaft is inserted into the firewall. If the shaft is not in the proper orientation or if it is not fully slid on, the pinch bolt cannot be installed.
Once the shaft is fully seated, and you are sure the other end is through the firewall, go ahead and install the new pinch bolt and tighten it to 23 foot pounds.
Relocate yourself to under the dash and find the shaft. Extend it to reinstall it to the steering column. Once you seat it in the original location, go ahead and reinstall the original bolt and tighten it to 23 foot pounds.
That’s it!
Now, properly dispose of the old junk:
Of course undo however you held the steering wheel, and then get the car safely on the ground. I noticed an immediate difference in steering response and had a lot less play in the wheel. This is a huge improvement over the stock unit and I highly recommend it.
If you are like me, and you have some other little projects to take care of while the silicone dries, I would do it. While I was waiting I went ahead and reinstalled my back seat, as well as my trunk mat because I had a car show. Since the car will be stored indoors from now on, I am not too worried about the seats getting messed up. Anyhow, pics of that stuff!
I also made a quick little mod list for the car show. It was not all inclusive but hit on most of the good things. In the future I will obviously make up a nicer one. This was just a quick and dirty.
Thank you all for looking!
