Also helps if you heat it up with a hair dryer or heat gun
Yeah you can feel it through one of the holes inside the decklidI used a credit card, but it had just expired so getting it messed didn't matter to me. And definitely heat it up. It will make it a lot easier. I used some rubbing alcohol to get the rest of the glue off the car.
Does the trunk badge have alignment pins as well? I want to take the ford badge off.
what should you use to put the new one on?
