justi88
Damn so much opinions jaja, ill do what modo says on the oil and drive it like 945.0 GT.
Yeah everyone has their own opinión, one last comment, when to the mechanic today.. he told me to buy 20-50 in that cheap national oil we have for the break-in and then change to the 10-40 in shell after the break-in, he prefers this oil instead of castrol. Does this seem ok?
Ok, when I was in there army as an aviation/armament/wiring tech i had the opurtunity to take a semester college course in engine rebuilding and engine theory, so those are my credentials. what was taught was that a proper break in procedure is this (under i deal conditions). if its in a car already, fing a long stretch of empty high way road, etc. in second, or third gear. run the engine up full throttle, let it come back down, repeat. congrats, your engine is 100% and in its prime. to dispell other myths. the why. Oil coats the cylinders, and the slowing rpms wipe them off in the best way possible to condition the walls. change oil if you want to be extra anal and then at 500 miles, cant hurt, chances are it wont do shit. sitting there and just reving the engine = bad by the way. bringing the revs up and popping the clutch also = bad.thats weird, what ive heard from mechanics and guys here is its crucial to always drive it with low rpms for about 500 miles, but if you guys say ill drive it like i stole it
dude, you do realize if the cheap national oil is substandard oil it will contain sulfides and what not that will shorten the life of the motor. not as if using it only once will realy have a seeable affect, but it doesnt matter, these rules apply to all engines regardless of make, model and the person who rebuilt it. auto mechanics arent always right, i learned that lesson the hard way.Go with whatever the engine builder told you to do. Dont take his info and come back here and look for conformation on what he said. Hes the one that built it no one on here has seen touched or had anything to do with working on that engine. When you come to forums anywhere you are going to get tons of different answers as you have seen for yourself now, some good some bad. Everyone is entitled to an opinion but does not mean its good info. Go with what the guy says who knows the engine better then anyone else.
And what I'm saying is the guy who rebuilt his motor his motor could be a very good mechanic but he is still ignorant to the chemical properties of oil. I just read back through the posts and he said the nationL brand of oil lasts for only a thousand miles. With a break down rate that fast it is high in sulfer, many other things, low in detergent, and could quickly become a weak acid lubricating brand new bearings, rings, cylinder walls etc shortening the life of the motor. I'm no master mechanic by any means but I do have personal expierience and a formal education on engine theory, rebuilding, and history of why engines have improved over the last 100 years. The biggest reason engines last so long now a days is quality of oil. That doesn't matter who your mechanic is.internet based opinions are not always right either. There were a lot more questions pertaining to the break in proceedure then just what oil to use, my quote was geared more towards that then the actual oil based question b/c everytime the enginer builder gives an answer the OP is looking for conformation here and getting answers all over the place.
