i hate little snags.
Petek
So, i got home from work early today, and felt ambitious, very ambitious. Pulled upper and lower control arms, brakes, quadshocks, and shocks, only to find out i cant find the right socket for the abs sensors. DARN. im 2 bolts away from pulling the rear end and driveshaft and now everything is closed :nonono:. oh well i guess it will have to wait until monday :wall:.
realitygt
cookie doesn't like snags either.
uncltrvlnmatt
Pa.
I had the same issue removing the front shocks/struts from my car. It really sucks when a stupid thing like a 21mm wrench is at home not in the garage.
P
Petek
i think im going to get my axle housing powder coated gloss black, im also ditching the quad shock mounts. Its gonna look SLEEK. :TY:.
ryclef331
well you probably already bought one BUT if you pull the back seat's bottom cushion, the connectors for the ABS harness are hidden under there. You can unhook the harnesses, pop them through the grommets out of the bottom of the car! I would do it that way regardless b/c those sensors tend to sieze themselves in there and break easily when you fight them.
riored96gt
SoCal 909
This is the reason I contribute to this forum...this info could save hours!
Thanks, Ry
hey Ry, where is the front pass.sensor hidden at?
i need to change it so my ABS can go away. :knuppel2:
19mustang95
look behind the brake rotor, behind the dust shield. it is right there, closer towards the front of the car.
sorry i should of been more specific,i knew it is behind the dust shield,but i wanted to know where is the other end. Thank DFG
g_dogg
how long did it take you to remove upper control arms and lower control arms???
