IAC..timing idk...
A_+
A_+
Kinda dark out but here are a few....
Addermk2
Pcv system is hooked up wrong, tubular GT-40 manifold (nice), fox tb conversion looks to be done correctly. Does the car have a hanging idle? I would assume so, especially since the PCV system is wrong.
A_+
A_+
I don't even know where the pcv is on a gt40. I just started experiencing a little hanging idle today. Last week I kept having a surging idle.
Addermk2
See the rubber capped elbow coming off the top of the TB? That should have a rubber hose run from it, down to the oil filler neck. There should be a nipple on the filler neck to receive the hose.
3/8" IIRC.
Then get rid of that damn breather. Get a real oil cap.
A_+
A_+
3/8" IIRC.
Oh yeah! That'll probably help get rid of the intake whistle too. Yeah, the breather came on the car. I never ran one. Any idea why someone would plug up the pcv?
A_+
A_+
Alright, I put in a new tube but left the breather, ill buy a cap this weekend. As far as vacuum lines go, nothing is left open. Its either plugged into something or capped off. Maybe I should try and put the chip back in. Feels a little sluggish right now.
rz5.0
Great state of TEXAS
Those lines that come out of the passenger side fender it has a red line green line white line and i think brown.. What is it hooked up to?
A_+
A_+
The tps? That has been spliced to some other wires under the upper manifold. ....if that's what your talking about....
A_+
A_+
Oh. Vacuum. Some are capped a few go to the tree that's on the drive side fender. I can't check now, I'm at work.
rz5.0
Non should go to the driver side. The driver side tree is for ac cruise and brakes.
Those lines are one for the egr one as a vacuum source two for the smog pump bypass...
