Ivan12's 1995 GT (finally Dyno tuned 11/8)
ivan12
I was bored at work today and thought I might start my own thread and keep updating the build as I go along.
Details on the car; It's a 1995 Mustang GT vert in DFG. Bought the car off my cousin who's brother sold it to him about 6 years ago. The car ran like poop when I got it, and as soon as I did a tune up it came back to life, at the time it was mostly stock with the exception of 17" cobra wheels, a "custom" x-pipe that had all kinds of different sized tubing, flowmasters, CAI, and a stage 2 or 3 comp cam which I later realized was the source of a lot of problems. I've learned so much about mustangs and cars in general because of this stang, and a lot of them have been lessons learned the hard way. It's been a love hate relationship since the day I got it and for that reason I don't ever plan on selling it no matter what family members or friends say that I should justH cut my losses and look into something else. It's been a total transformation since the day i got that pink slip handed over, my interior went from tan to black with 00 GT charcoal leather seats, tan to black top, and 17" cobras to 18" Saleens.
List of Mods (interior):
Black interior
03 Cobra seats all around
FR500 steering wheel
Autometer Nexus gauges. Oil, water temp, boost, wideband, and fuel pressure
Steeda Triax short shifter (TKO600 sitting in storage waiting for install)
Styling light bar
L.E.D. Gauge cluster bulbs
New edge double din radio bezel with matching shifter bezel
Double Din touch screen head unit
Exterior Mods;
Kaenen S281 spoiler
Cervinis Cowl hood
ABCexclusive side exhaust covers
Clear headlights
Vertical tail lights
Speedster cover
Shaved emblems and antenna
Mach 1 chin spoiler
Exhaust;
JBA shorty headers
Bassani catted X-pipe, Mac Prochamber
Borla side exhaust
Engine
TFS top end kit
Stock bottom end 302 with stock 92 mustang internals
D1SC Procharger kit with stock pulley and 12-14 psi pulley with 8 rib setup
Totally stainless polished 12 point bolt kit
ARP Head, main, and connecting rod studs plus oil pump shaft
Powerbond Harmonic balancer
Professional Products TB
MM Quadrant, firewall adjuster, and clutch cable
Steeda battery box kit
Moates QH (now tuned with SCT)
Livewires and screaming demon coil
Wire tuck
Suspension;
MM adjustable LCAs
Team Z UCAs
Team Z tubular K-member, A-arms, and bumpsteer kit
Strange 10 way adjustable coil overs
MM C/C plates
Cobra (PBR) brakes with Baer 13" rotors (Brembos waiting for install)
MM stainless steel braided brake hoses
Cobra MC
Misc.
3:73 gears
Powder coated accessory brackets
Powder coated pulleys
Powder coated alternator and smog pump
I'm pretty sure I left out a couple of things but I'll add them once I remember.
When I first got her
In the process
During tear down process
I'll also add some pictures once the engine gets dropped in and some process shots as well.
Maximum95
Albuquerque, New Mexico
Re: Ivan12's 1995 GT
Dude it sucks to see the car torn apart like that :( but I mean took at that motor!
I'm jelly bro, keep posting pics!
Marvin97
Glasgow, Ky
TFS top end kit
0 mile 302 with stock 92 mustang internals
What kind of power you expecting from this setup? Nice looking motor for sure
ivan12
ivan12
Thanks for the compliments guys, keeps me motivated
97whitevert said:
TFS top end kit
Hope to hit 450rwhp with stock fuel components, would love to see 500. I'm going to start with the stock pulley first though
i like the engine pics.
let me get this straight, you want 400+ out of your stock fuel componentes? can you be more specific on the "stock fuel componentes"?
just trying to help here bro :thumbsup:
Slykin
Tyler, Texas
If only you could run with no valve covers. That's so freakin sexy.
ivan12
ivan12
I should've been more clear, stock rails is what I meant. I already have a high flow 255lph in tank plus the Procharger 190 in line, which I probably won't run since I've read that it might be restrictive to the in tank pump. Plus I have 60# injectors with matching MAF. I would like to buy a fuel rail kit but I can't spend another $600 plus feed and return lines with fittings to the firewall right now. I hope I don't run out of fuel on the dyno, I've looked up the sumped tank and dual pumps and that stuff is pricey. I guess it goes like the saying "you gotta pay to play"
That would be sweet, how about some plexiglass covers?
ivan12
ivan12
I took some updated shots this morning, my brother hooked me up and started sanding down parts of the engine bay so they can be filled in tomorrow.
And a shot of the suspension coming along
No need to sump the tank at all, you should be fine with 60lbers and the rails are good up to 600s (cant remember)
you'd probably split the block before you run out of fuel.
ivan12
ivan12
It was a long day and lots of work but I'm happy with the way it's turning out so far
ivan12
ivan12
Went from this
To this
I have a couple of spots where the paint ran a bit but I hope I can just sand and repaint the areas. I was able to shoot everything with 2 spray cans but bought 3 just in case.
Slykin
Tyler, Texas
Is that supposed to blue or is it just weird lighting?
ivan12
ivan12
It's DFG, it's probably the way the light is hitting it
CoD_50callongshotz said:
you rattle canned that? if so that looks awesome for a spray bomb! good job
I went to a local auto paint place and they took a pint of DFG and made it into 3 cans with the clear mixed in. It looks really good in person, I'm glad I took the time and effort with the prepping.
ivan12
ivan12
I don't own a pilot bearing puller so I went to Autozone and rented the very expensive tool. Had the engine on the engine hoist and decided to go at it. Well I don't know if this is very common or not but the pilot bearing decided to come out in 2 pieces. The puller only got the inside bushing with the needle bearings and left the outer housing in the crank. Had to chisel and grind it for almost an hour until I was able to break and remove it.
Pic of the carnage
Once the pilot bearing and clutch were installed engine went it without a hitch
T's Convertible
