Just bought a 94 gt
Fast stang16
I just picked up a 1994 gt with a 306, trick flow heAds, x303 cam, forged crank/rods/Pistons 12:1. Edelbrock intake, 24lb injectors, under drive pulleys, 70 mm throttle body, 1.6 roller rockers, bassani exhaust, 4.10 gears, and I'm sure there are more things i haven't found, the guy didn't know if it has a tune or not? Would it run very good with this set up if it didn't? What do y'all think this car should run? It's a 5 speed
lutter94
South Dakota
Wouldn't hurt to take it to a tuner, at least it lets them check it out, prevents a catastrophe....lets see some pics!
F
Fast stang16
I will post some pics up in the morning, everything seems solid, I just think it should run alittle faster on the top end than it does
F
Fast stang16
I'm new to the whole 5.0 scene so forgive me if I ask any dumb question! Lol
the5.ohh
Shaolin, NY
On the passenger side under the glovebox, right hand side. Pull off that kickpanel. See if you see a chip in the computer
F
Fast stang16
Ok thanks I'll check tmrw! Any idea what kinda power I should be pushing? Who is the best at tuning these things? I live in east texas If that helps any
the5.ohh
Shaolin, NY
Np. That setup should net atleast 325 rwhp in my opinion. Not sure about Texas since I'm in new york. I'm sure one of the texas members will chime in here. If not make a new post in the garage section asking about tuners in texas, might get more attention
CC'S95GT
Hampton ,Ga.
Welcome to the asylum.
IMO with those mods it would barely run without a tune. But that's not saying the PO didn't get some generic mail order tune. You'll get much better results with a dyno tune
lutter94
South Dakota
Just because it has a chip, doesn't mean its properly tuned. Best bet is getting a dyno pull.....cheap insurance.
F
Fast stang16
rz5.0
Great state of TEXAS
So the guy should go spend 300-600 on a dyno tune just in case? Man.. If the car runs fine no issues I would leave it alone?
DavidBoren
Pacific Northwest.
No, he should go get a dyno tune because a dyno tune is always beneficial. And when it comes to buying something built by someone else, even $600 for a good dyno tune is ultimately cheap insurance against blowing up your motor.
Anyways, welcome to the forum. Good score from the sounds of it. With such a high compression ratio, are you only using premium fuel? What are your intentions/plans for that beast?
F
Fast stang16
I put premium in it last night I don't know what he ran. The reason I posted is because it seems someone fast I just thought it would be faster, but I am coming from a built 2012 duramax so that may be the problem? Lol
EdgarR213
