Win
I have been looking at the STR-T's but have not pulled the trigger. Might be thinking used bilsteins now.
Anyway from what I understand about fox and sn-95 shocks and struts.
The rear shocks are the same except the fox shocks do not come with internal bump stops.
The front struts are longer on a fox than they are on a sn-95. this means when lowering you will gain an inch of travel by using fox struts on a sn-95. BUT!!!!!!!! this also means when your car is lowered your tire will travel and extra inch into the wheel well and rub or rub right through the well cover. Guess what is above the well cover????? your wiring harness! So be careful with fox struts on a sn-95.
so should I get the str-t's???
Bilsteins
i paid 200 or 225 for all 4 of my Bilstein HD's
struts only had 2,000 miles and the shocks had 5,000
