Lightning Swapped Mustang, I mean, F150 Build Thread
97_281gt
BOOM
I wish lol just picked up this project today lightning swapped new edge. P.o. hit the oil pan lost oil and spun a bearing right in front of his house. Traded my high mileage v6 f150 for it. Got the car home checked out the cranked it's barley scuffed so gonna clean that up and put some new bearings check All the other bearings in it make sure there not tore up then put it back together.
P.o. also never had a heat exchanger on the car so gonna be hunting those parts down soon
Heres how she sits now
Car has some lowering springs cc plates rear control arms and 4.10 gears (have too see if that's true) and staggered bullets
Got the car cleaned up and washed all the dust off
And here's the little scratches on the crank
Post more updates soon already got some stuff for it lol but hoping to have the motor done and back together soon as long as there's no issues
Sent From Your Mom's Phone
evilcw311
Most Evil Member!
Louisville, KY
So this is totally sweet but how the hell do you see over that beast!!!!! Lol
97_281gt
97_281gt
It's in the middle just cant look right lol
I can bet a dollar wheel spin is gonna be a problem
Sent from my SM-G900P using Tapatalk
97_281gt
97_281gt
Yea that's why I'm Hoping it doesn't have 4.10s lol gonna check that in a few just finished cleaning up the cranks and checking crank bearings and there all good. Ordered new intake gaskets in oil pan gaskets last night along with new bearings and plugs. Just worked out a deal with a buddy of mine who wants my old Cobra block and crank for his heads with comp cams in them. Can't remember if the heads have worked on or not but should pretty good addition to this motor LOL have some parts I got yesterday too I'll post those up once I get them probably next week
white95
Apex Junky
Prairieville, LA
Do yourself a favor and do the M122 swap!!! You'll actually be able to see AND boost power with a larger blower. More room to grow too!!!
97_281gt
97_281gt
Eventually I will do something with the blower right now I'm just gonna put the cammed heads and a pulley for some more boost
98snakehorse
Southeast, IA
This is a cool project. Does the oil pan sit lower than normal on this swap hence why the crushed oil pan or was he just being careless?
97_281gt
97_281gt
Little bit of both he didn't swap the 4.6 pan and pick up in it and he was hauling ass and hit a dip he knew was there at like 80
97_281gt
97_281gt
Holy crap I don't think I've owned a dirtier car. Guy was a smoker so of course it stunk and the ashes left like a gray film everywhere stains everywhere seats carpet center console. So tries to get that cleaned up some today
Before
After
evilcw311
Most Evil Member!
Louisville, KY
Saddest part is what smoking does to the wiring and electronics in your car. It destroys everything much faster cause the carcinogens eats at it.
97_281gt
97_281gt
Hopefully I won't have any problems
I use to work at a car audio shop that rented its install bays from a neighboring limo/detailing biz. I was amazed to see them using steel wool to get the stains off of some of the more extreme cases and even after a good wet vac it looked much better but you just could not hang enough air fresheners to cover that smell. These were cars though that the windows were seriously hazy from the smoke, yours doesn't look that bad.
If it were not for the fact I know that cigarette smoke smell will soon be covered with the aroma of burning rubber smell I would say to replace the carpet...
97_281gt
97_281gt
Yea I thought about just replacing the carpet. I was gonna try one of those odor bombs people were having good luck with those but need the AC on to use one
97_281gt
97_281gt
Been slackin on updates here. But sold the mustang and keep the motor and picked up a f150 with a messed up motor for 750 decided I needed a truck more then I needed two mustangs.
I'm gonna keep going with this cause I want a build thread for the truck lol
So had the whole motor tore apart cleaned up the crank picked up a set of gt500 rods from a friend of mine that works at vmp so the bottom end should be good for 700ish now. Picked up a set of low miles heads with stage 2 comp cams in them also have the 6 pound lower pulley
Forged short block back together
Long block ready to go back in the truck
97_281gt
97_281gt
Started tearing the truck down last weekend got the whole top end apart
Also found out the 4r70w in stock forum will not hold up to the torque of the lightning motor so didn't have a few grand to spend on building a motor so I looked around for a 4r100 swap ended up finding a complete swap minus ecu for 400 bucks and picked a ecu from the bone yard on Wed so that will all be getting swapped in with the motor
Hoping to have it swapped next week fingers crossed
jeanfltns01
