Misfiring issues
J
joshuaw3
Ohio
What do you mean like return the car to stock? Won't it just throw the egr code and rear o2 code?
J
joshuaw3
Ohio
Well I set it to stock and it was like 5x worse than what it was with the tune. I changed which tune I was using so let's see if that does anything
DeepList
Administrator
Auburn, IN
^ It's going to run like shit if you put the stock tune back on, and the EGR functions are enabled, but the EGR system is gone.
DeepList
Administrator
Auburn, IN
It goes without saying, that since you removed the EGR system, you'd have to deactivate those functions in your stock tune... or if you don't want to modify the tune, you need put the EGR components back on the car. You should have just left them on there in the first place since removing the EGR provides zero benefits other than a cleaner engine bay. That's it.
J
joshuaw3
Ohio
Well the egr tube connection was broken the threads in the connector were completely stripped out and I couldn't get it to stay on so I took it off. I would love to put it back on but I'm tired of spending money on it. Next car I get I'm getting any upgrades professionally done at least tuning wise. All I want now is for this car to be a good daily driver and not have any more issues.
DeepList
Administrator
Auburn, IN
The mail order tunes from bama are notorious for causing problems. Some people have had good experiences with them, but probably equally as many (if not more) have reported issues. For the money you spent on that, you should have just had the car dyno tuned at a shop.
J
joshuaw3
Ohio
I didn't know any better at the time. I guess I've learned my lesson. Oh well I'll keep on messing with it and see what happens
J
joshuaw3
Ohio
I just don't understand why it took two months for it to start having the problems. Could it possibly be the head gasket my friend thinks that may be it
DeepList
Administrator
Auburn, IN
Have you noticed if your oil a milky or creamy color? Does the exhaust have a "sweet" smell to it?
J
joshuaw3
Ohio
No milky or sweet smell it's throwing a code for the bank 1 upstream o2 sensor could that really be causing the problem?
DeepList
Administrator
Auburn, IN
That's your passenger (right) side, front sensor.
At this point, you may want to have a shop look at the car.
J
joshuaw3
Ohio
I did have a shop look like week one they found the coil pack was messed up but it didnt fix the problem then they spent 4 hours trying to figure it out and they couldn't. Ill probably just take it to ford at some point
D3VST8R96GT
Marble Fall, AZ
Compression test and leak down test?
Just curious .
Also you bought a sensor for the drivere side? switch it out for the passenger side see what happens
THE D3V
J
joshuaw3
Ohio
My friend said I should do one but autozone doesn't rent it so I'd have to buy it. And yeah I think I'll try that soon
ster302
Madison, wi
I've just read this whole thread and I'm a little confused, Let me try to get some of these things straight. You've have bank 1 throwing misfires on all cylinders and two codes indicating a rich condition on that bank. Now you've obviously found some damaged/bad parts and replaced most of them right? The problem I see is the re-occurring rich codes. Did you check the injectors? If one or more is failing it will effect the O2 on that bank, obviously. The way you describe the symptoms and when they're occurring is making me think a injector is failing mechanically or electrically. Ford service information states that both of the rich codes you have are more likely a result of a condition than a indication the O2 failing. How does the engine run otherwise? Idle smooth? Does it Rev okay when not under load? Another thing to check is if a injector is leaking, hook up a fuel pressure gauge and turn the key to prime the system, watch pressure drop on the gauge. I don't have the spec in front of me for psi vs time but if holds pretty steady for say 5-10 mins than you're probably okay on leak down. If it doesn't hold than any of these three things could be happening leaking injector, failing FPR, and/or failing fuel pump check valve. Dripping injectors can be found by removing the fuel rail and priming the system, watch for leaks. I do drivability diagnostics every day at work so I know how frustrating things like this can be. Good luck.
IDTag
