My 4.6 2v engine.
Javier
Hi everyone, Still not done but here is what's been done so far, it started but is rough and it won't keep idle I'm pretty sure a tune on the ECU is needed, I would love to get some advice and what you guys think.
Mod List.
PI Heads With Compcam XE262H-14
Oversize Valves Port and Polish
Modmax CP Pistons
Manly HBean Rods
OverBore .30
Meling Oil Pump
Pypes Long Tube Headers
TCI Super StreetFighter 3500 Stall Converter
Ford Racing 4.10 Gear on Differential.
Stock 19lbs Injectors (for now)
Walbro 255lph Fuel Pump
MSD Coil Packs
Cold Air K&N Filter
---Soon to Add---
Steeda 555-8200 Sport Lowering Spring.
Wheels Front 18.9 Rear 18.101934073_1189265006390_3585091_n.jpg 1934073_1189264686382_4152128_n.jpg 1934073_1189264486377_690274_n.jpg 1914700_1212461106278_8375616_n.jpg 66121603_10216639488714254_5677810404395319296_o.jpg 66123428_10216639488194241_777972796696297472_o.jpg 66165848_10216639489434272_768719220937588736_o.jpg 66434206_10216639492474348_4918491887616131072_n.jpg 65277543_916383758729195_6057380518591201280_n.jpg 65300863_889018611432844_2636422978379710464_n.jpg
98'Coco'GtVert
Mod List.
Modmax CP Pistons
Manly HBean Rods
OverBore .30
Meling Oil Pump
MSD Coil Packs
Cold Air K&N Filter
---Soon to Add---
Wheels Front 18.9 Rear 18.10View attachment 1587 View attachment 1586 View attachment 1585 View attachment 1584 View attachment 1590 View attachment 1591 View attachment 1592 View attachment 1593 View attachment 1588 View attachment 1589
Could be the tune bro, or possibly too high of a stall converter i was thinking a 2800-3000 stall would be perfect bro
honestly, if you kept the same maf and injectors, your car should start up and run just like stock. You didn’t go with a wild cam, so the ecu can adjust for it. I would make sure you don’t have any vacuum leaks for starters.
To much stall on the converter maybe ,
a street /strip BAM shift kit for the AOD is good
Good looking build! Clean!
Will this build be forced induced?
Sent from my SM-G900P using Tapatalk
Javier
Javier
You know what I am using the same MAF sensor but I swapped injectors for remanufactured injector that are the same as 19lbs but it seen they have a different part number that is related to the ones that came with the car.
Javier
Javier
I built the engine for nitrous but I changed my mind I'm not going to put any power adder.
I can understand that! To expensive!!!
Mo power, mo problems.
Dont get me wrong, i love the power, its just to costly while raising a family.
Javier
Javier
Exactly, family just going to enjoy the car my kids can't wait to go for a ride in it plus with the current mods I have now I am pretty sure it will be a fun drive, I still dont know what a 3500 stall converter will do.
Silver95bird
i would think it should idle ok. try unplugging the maf while running, see if jt changes things. ditto for the coolant temp sensor. mine ran like poop intermittently until i found it by accident. then one by one with the injectors, then one by one with the wires.
make sure the tps is in range. and vacuum leaks. pcv, evap, egr, fuel rail all have vaccum lines. evap hoses especially love to rot.
a datalogger is gold if you can get your hands on one. seeing sensors in real time is amazing.
Sent from my moto z3 using Tapatalk
Carolinastang78
