Need ideas on how to build a mid 13sec 1/4 mile GT
jpeister
Need help building up my 1995 Vert this is for a program called beat the heat (beattheheatinc.org) What I have now is GT40 upper and lower intake, BBK Shorty headers, Mac off road H-pipe, tranny has mild shift kit and built up alittle (larger overdrive servo and such). pulling 16.028 @85mph in the 1/4 motor is pretty much stock right now..... HELP!!!!!
The kids in the rice runners are giving me a run for my money (not cool)
need info on heads and cam and all the go fast stuff looking to get mid 13sec cuz well faster and then I need to look into roll bars per NHRA regs...
BLOWN 95GT
Alabama
take the 25lb. weight off the front end I think there is a post in the 94-95 section look in weight reduction, you need to drop all the weight you can off of that vert. them things are heavy, afr185 or trickflow heads, custom grind cam or tfs stage 1 cam, 150 shot of nitrous.
castine917
wyoming, mi
are you driving it like you stole it? check timing, plugs, and rest of tune. those parts should be faster even with vert. in decent weather of course.
DFG_magic
Kennesaw, GA
Seems very slow for the mods and gears. You should be pulling at least mid to low 15's with your current setup at factory weight. Since it's a vert. Like said above, check the timing and all ignition related components. (Do a nice tune up). Add a 2 step especially with that automatic and you'll see your 60' times improving. Also, what is your rear suspension looking like? Tires?
J
jpeister
the 4.10 are not in it yet I am still running the 3.27s
J
jpeister
modo said:
what torque converter is in the car? the right converter can shave a lot of time off a et
Ther car has a 2600 stall converter in it now
J
jpeister
Well I need new shocks which I have and just need to put on... And the tires are 275-40-17 BFGoodrich G-Force
Adam95GT
I ran a 14.4 @ 96 with just a CAI and Midpipe... But then i can launch a car pretty damn well.. Whats your 60's looking like?
modo
Philadelphia, PA
60' is mute based on his mph of 86. car is not making the power it should or there is a issue with the trans
.02
stangman1995gt
Im lost you have all this in the stang now and only running 16's? I run a 14.8 with all I have (SOME weight gone, 4.10, CAI, OR h pipe, flowmasters, I leave at 1800 rpm due to stock converter and shift. A better tourqe converter and a valve body and some tuning and I should be in the 13's.
J
jpeister
stangman1995gt said:
Sorry you must have miss read what I posted ...
Sorry I must have miss worded the post wrong I have the GT40 intake just not on yet and I have the Headers just not on yet as well as the 4.10 gears just not in yet.... The car does have the 2400-2600 stall converter and the off road H-pipe and other then that its stock.... Running 16.028 @85mph now it does have 250,000 on the motor with all new gaskets due to an oil over fill... NOW I am going to do a full tune up plugs, wires, fuel filter oil and air filter... That should help looked at it to day and yep has prob not been dune in a long time.....
Rice_slayer
Check your MAF, My car was running similar times, swapped out the MAF and dropped it to a 15.1.
J
jpeister
Thanks will do think that maybe part of my tune up along with a new throttle body thinking 65mm or 70mm
JJhirsch
White Bear Lake, MN
wow man i had a 94 gt coup Auto back in the day with off road h, CAI, and i ran a 14.7 at 98mph with just a little advanced timeing and some 93 gas.
your car probably weighs a few hundred more then that car but damn 16.0
yeah before you upgrade make sure you get your car tuned up because there is something wrong.
check what your 60 foots were they should be 2.1 or better and if not then you were spinning or something.
J
jpeister
Oh yeah the car was deff not hooking up at all I will have to look at the 60' times and get back to ya...
