Nick's 95 Stroker Turbo Build
meanmachine
miami fl
dude lovin the ride.. do you have forged internals? you got a sick deal on those wheels with tires for 400 tires alone are like 6 700 bucks
ever think about changing taillights to verticals from 96-98? i just bought a pair gonna plastidip it and wet sand gonna loook sick with the s281 wing
98snakehorse
98snakehorse
Southeast, IA
Thanks man. Yes forged rotating assembly. And I wouldnt mind a set of verticls but the stock ones dont bother me too bad... its the only identification of the 5.0 sn95 platform.
98snakehorse
98snakehorse
Southeast, IA
Some more eye candy after this weekends car wash. :)
98snakehorse
98snakehorse
Southeast, IA
I'll be excited to see what it runs! Are you going to lower it anymore than it is? Or is it at a perfect height for you? (Back tires have a nice gap)
Well i'll be getting some drag springs, drag shocks, and finishing off my rear suspension here shortly. Im not sure what that will bring the ride height to but i'm more aiming for drag than looks.
Musturd
It's deff the MM one. I have the same one in my yellow car
98snakehorse
98snakehorse
Southeast, IA
got it for 100 bucks out of my buddies 04 mach1 and it was lime green lol...... I thought dark ford blue would look good no? haha. Downfall is it doesnt have the swing out bar that it should. does anyone know where I can pick a set up?
Musturd
You can even check with MM direct . I painted mine matte black goes well with my interior
98snakehorse
98snakehorse
Southeast, IA
hmm i'll have to look into that. Yeah I have quite a lot of black padding that will be going over the cage, So im not so sure the blue will be seen much anyways. I have a lot of blue under the hood and was gonna try to match it with that.
RonBurgandy
Pikeville, Nc
i want to do a super charged or turbo 331 in my 95. what made you go with the turbo over the sc? and how hard was the assembly and build?
98snakehorse
98snakehorse
Southeast, IA
Thats a good question... The main reason I chose the turbo over the supercharger is because I have never delt with a turbo car before and really wanted to learn. Another reason is that the turbo has the capability to make a lot of power more easily, (just cranking up the boost with the simple turn of the boost controller). The assembly will vary with what turbo kit you purchase, and even that can differ in some cases. From a rating of 0-10, 0 being easy and 10 being hard, I would give this kit a 6. My ac was already gone so I didnt have to deal with that, I had to delete my abs system, cut my brake lines and tie them back together. I had to space my motor up on the driver side about a 3/4 of an inch to clear room for the header. Move around my blaster coil and wiring on the passenger side to prevent cooking them to death. Those were the major hurtles. Would I say it was worth it? Ofcourse, I enjoy doing this stuff and I have learned alot on the way. Cost wise if your going to spend big bucks on a turbo kit I'm thinking it will end up costing you more in the long run, I chose to buy a cheaper model of turbo kit, and after buying all of the accessories..... pump, injectors, heat wrap, and my megasquirt ecu, I could have had a pretty nice supercharger sitting in there. Not to mention when people ask to see my engine, and once I pop the hood they see a fat turbo staring them in the face.......its priceless. :)
