Anyone know of a good nitrous kit that is pretty complete with most parts included? I know I will likely have to buy a bottle warmer separate, but I'd like to get something thats most to complete as possible. Only looking for something in the range of a 100-150 shot. Slightly off topic, I can't seem to figure out to edit my sig on the new forums :lipsrsealed:
I am running the Zex 82023 kit. I have a few extras with it. I recommend the bottle pressure gauge, some sort of purge kit (I run Zex 82175) and what I consider absolutely positively mandatory a window switch kit. I use a MSD Digital Window Switch 8969. Between the Zex wide open throttle box and the window you are pretty safe with a good tune.
I say run an 83023b for the blackout kit and run a purge kit for sure, this kit has tps switch for wide open throttle. not sure if a window switch would still be needed or not. Looks like almost everything you need is there tho
Ok so I got the blackout kit, with the dual outlet purge kit (http://www.americanmuscle.com/zex-dual-purge-kit.html) and zex safety blow down kit. My only question is on that digital window switch, it says its for 96-04 stangs. I know 95's are the last year of the ODB1s and we don't have the same computer setups.
Doesn't matter, the MSD window switch has a setting for V8 cars with distributors. It will work, if in doubt call MSD, they're very polite and fast. I would recommend a bottle pressure gauge. http://www.amazon.com/ZEX-82005-ZEX...550&sr=8-1&keywords=zex+bottle+pressure+gauge It literally took me five minutes to install. Nitrous looses a lot of impact if the PSI is too low. You want about 950 bottle PSI.
