OLD H2S
I do not know yet, I have only done number 1 cylinder to check the valve interference and the valve is not even touching the clay? How could I screw this up?
Looking good! The pvc that comes with the MM kit wasn't even close to square up the hole for the rear supports, however your install came out great! What side is that square tubing if you don't mind?..like to link my subframes to the bottom of the roll bar mount plate.Here's the proof you can put in the Maximum Motorsports roll bar without cutting up the rear side panels, it was not fun....
This is the bottom stiffening plate for the roll bar. I welded it in and added tie in bars to the Steeda subframe connectors. Now I have a strong place for a jack point and the roll bar is welded to the sub frame.![]()
