OLD FARTS "It never ends"
OLD H2S
OLD H2S
Silver Spring Maryland
I do not know yet, I have only done number 1 cylinder to check the valve interference and the valve is not even touching the clay? How could I screw this up?
Staff member
Lawrenceburg Kentucky
Man im only asking. Be like a "check list". Not trying to badger you. Did you use different valves? Mash the valve inyo the clay, checking lift measures while doing it.
OLD H2S
OLD H2S
Badger on I need it, helps me remember what I should be doing. I was using a solid checking lifter and it was lifting the valve off the seat?
I put in a regular type lifter and pushed down to check the clearance between the roller and cam and got .023 and the spec is .016 to .032 so my valve stem height is right in the middle of the spec. I built up the clay and still did get any mark in it so I am assuming my duration is so low as to not be a concern which in itself is a concern. After cutting .080 off the heads and block and no interference, amazing. I looked for cam simulation apps but they are all 100 bucks and up so I think I will use a bigger wad of clay.
OLD H2S
OLD H2S
I had to cut down the solid test lifter about 10 times to get it to zero out and then I got a good test mark in the clay to measure. I have a ton of room, I could retard the cam some...
OLD H2S
OLD H2S
I made up 2 extended chain tensioner extenders but doing the mock up the drivers side chain is is not as loose as the right side is? I think some adjusting is in order.
OLD H2S
OLD H2S
I had to scrounge around for a 12 point 7/16 1/2 drive socket to torque the connecting rods. Then on to what to torque a used set of "03 Cobra rods, lots of numbers out there from Manley, ARP, you,me.. with oil, with graphite torque lube, lots and lots of advice. I settled for the measure the stretch of the bolt method for the used bolts as the best way to get the right preload stretch no matter what the torque number came up to. I did not have the cool custom tool to use so I used an old caliper that had a dead magnetic zone in it and welded on some pins to match the pics on the web and bang zoom good to go. The bolts are 1.720" long and .005 to .006 is a good zone for used bolts and that was 50 LBS of torque coming up 5 pounds at a time.
OLD H2S
OLD H2S
OH CRAP!!!!! Did I put the little oil plugs back in the bottom of the heads??? I was looking at the tear down pics on the 2V tech thread I have and I might have forgotten to put the plugs back in.
OLD H2S
OLD H2S
I left the plug out. BUT, it is on the outside bottom of the head, just really hard to get to. I cut down an Allen head wrench and it was easy. I just get a new one.
OLD H2S
OLD H2S
Here's the proof you can put in the Maximum Motorsports roll bar without cutting up the rear side panels, it was not fun....
This is the bottom stiffening plate for the roll bar. I welded it in and added tie in bars to the Steeda subframe connectors. Now I have a strong place for a jack point and the roll bar is welded to the sub frame.
OLD H2S
OLD H2S
A lot of wiggling around and a big brass hammer to seat the second back bar, the first bar goes in easy. I did by myself and I was dripping and worn out by the time I was done.
neverenuff
Looking good! The pvc that comes with the MM kit wasn't even close to square up the hole for the rear supports, however your install came out great! What side is that square tubing if you don't mind?..like to link my subframes to the bottom of the roll bar mount plate.
Sent from my SM-G935V using Tapatalk
OLD H2S
OLD H2S
It is 1 1/4 " with 1/8" wall.
Here is what I did today, I coped the round 1 3/4" diagonal cross brace to the overhead main bar. The angle is holding up the tubing while I make little marks on it to remove and then test fit again and again. The big cable is the negative battery connector. Next up is cleaning up the weld spatter and the seam sealer and some SEM trim paint.
OLD H2S
OLD H2S
Here is a shot of the rear seat delete installed, a little more trimming and it will be done.
Next is mocking up the rear Cobra brake kit from FTR.
OLD H2S
OLD H2S
The rotor in the pic above is the Baer 13" which really is 13" in diameter and rubs on the outside edge. This pic is the Cobra front rotor which is 12.88" in diameter and have just a little clearance and do not rub. This wheel is 18" and 45mm backspace.
This shot is the stock 17" with 35mm backspace.
This one is the 18X10, lots of room.
OLD H2S
OLD H2S
I'm back, Thanks to the ADMIN. they are shaking their heads at my dumb mistakes. I got a real mess on my computer trying to download a PDF of how to rebuild a T45 transmission. Took a week to clear out all the contaminates and it really messed up this site for me. So you missed the tranny rebuild in all it's glory and faults as I put it back together with new parts. Not all that hard to do but the sequence has to be right and I would get too far ahead on one shaft and have to take it back apart to put a corresponding part on the other shaft in the right order. But all is good and here is a pic. of the problem that required the clutch needing to be adjusted every 4 days that started the whole rebuilding of the car in the first place.
96GTPlanB
