Ponystop nmra coyote stock build
waynebuilt
Old setup of my Ebony Black 97 Cobra
1997 SVT COBRA
Interior 10/10
Clean title
98k on chassis
PPG ebony paint
Maximum Motorsports caster camber plates
Maximum Motorsports bump steer kit
UPR coil over sleeves
Eibach Springs
Bilstein adjustable dampers up front
Koni adjustable in rear
Kenny Brown 6 point cage
Hotchkiss rear upper and Lower control arms
Steeda sub frame connectors
cross drilled and slotted rotors
carbon pads
SS brake lines
Fr500 17/10.5 rear 17/9 front
Nitto 555 275/40/17
Nitto Nt05r drag radials 315/35/17
<Kenne Bell 1.7 Supercharger
BBK cold air intake
Accufab monoblade tb
90MM mass air
42 pound injectors
IMRC delete> for sale
Magnaflow catback 2.5
Mac H pipe 2.5
king Cobra stg2 clutch kit
Tuned @ DMP ( Dontes Modular Performance) 420 rwhp @ 10psi
SCT handheld
@ the Ponystop in Reseda ca.
Coyote stock class build parts list
NMRA Coyote stock sealed racing engine M-6007-M50S*
Ford Boss 302 alternator kit
Power by hour 1996-2010 Coyote accessory bracket kit
Coyote Street Accessory Bracket Kit
Coyote swap pedal bracket
OEM 94-95 5.0 Radiator
Electronics...
Ford racing control pack
MSD 2-Step Launch Controllers 8731
Ford Racing Speed-Dial
Front-end Suspension...
Maximum motorsports k member
Maximum motorsports ctrl arms
Maximum motorsports bolt thru bump steer kit
Maximum motorsports rack bushing kit
Exhaust...
Bbk coyote swap header 1 ¾
Bbk coyote swap x pipe 3in
Mac 3 in cat back
Drive-train...
Transmission Built Cobra T45
Ram Oem replacement clutch
Ram billet steel flywheel
FRPP Aluminum drive shaft
Rear end FRPP 4.11 & 4.56
Mounts...
99-04 Mustang Prothane 4.6 motor mounts
96-98 Mustang Prothane transmission mount
Stifflers transmission cross member TCB-M03
FueL...
Walbro 255
Aeromotive Return FPR
Russell coyote fuel rail adapter
Red horse SBL #6 X 3' x2
Red horse SBL#6 X 6' x1
EARLS FTG AL TBE ADP -6 MAL 1/4
EARLS FTG AL TBE ADP -6 MAL 5/16
SUMMIT Fitting, Straight, Male -6 AN to Straight Cut Male -6 AN O-Ring, x3
waynebuilt
waynebuilt
waynebuilt
waynebuilt
Finished up Vader weight 3100lb ready for 2014 nmra coyote stock
That is gorgeous!
how much time you have into that little mod :) ?
Awesome. Just awesome.
I loved that take-off vid. The car must be quiet a beast with a Coyote motor and only weighing 3100 lbs.
duff daddy
Good luck Nmra cs is the IT class mean street champion, a few factory stock champs, and the king of 2v... Brandon alsept will all be playing. I'm interested in cm and how low that class goes
waynebuilt
waynebuilt
competition is stiff for 2014 im not using this car next year, Shane was awesome this year but still never best Joes mph record.
