Power wire
Insayne
How are you routing your power wire. I have 2 gauge trying to route and punching a hole in the firewall seems like a shity idea. I tried a grommet in the fender down just above the side skirt. But looking inside the kick Panel it doesn't come through to the interior. Is like to keep the wire out of the bay as my under hood temps seem a bit on the high side. Plus dangling wire by hot headers is clearly a dumb idea.
the grommet on the driverss ide(assuming its a 94) where the wires pass through is fairly thick and could probably fit it. Poke a hole thought it and either try to feed the wire through or use a coat hanger to fish it through.
I
Insayne
Which grommet. It is a 94 but I don't know what grommet your referring too
Musturd
Yea what ttocs said I ran two 4ga and a 8ga threw that grommet for my system and worked great
no in the firewall near the top. There is a LARGE group of wires that goes through and it has a big rubber surround that you can pass it through.
I
Insayne
I'll look on my lunch break. Where in relation to the brake booster.
gosh not sure with the brake booster. It is near the top, a good 4" and again has a LARGE bundle of wires already going through it. Around the outside the rubber is a good 1-2" thick piece of rubber that you can poke it through.
I
Insayne
It's thick as hell lol. I found it but it's a pita trying open it up lol
just poke a hole through it at first with either a box knife or screw driver, I sometimes will use side-cut wire cutters as well to make a small hole. Now run your coat hanger through it, tape the wire to the other end and now pull it through the hole.
I
Insayne
I cut a rather large x in it from the inside out because I accidentally slipped through with a pocket knife. I now need a hanger which is at home. Wasted my lunch cutting the grommet and rerunning the rcas to the back. Oh well.
I
Insayne
Oh you better believe I did big homie. I gotta pull the panel for the fat ass 2 gauge tho.
Ian
O-Town
Anyone elses rear speaker deck rattle?
Just pick up some dynomat and cut it to fit between the speaker and the chassis... Also feel free to add a piece of cardboard behind your lisence plate to prevent it from rattling too
I
Insayne
I don't think it's the speakers that's vibrating. It seems like its the speaker cover panel or the foam hump trim thing.
it could be the door panel, the speaker, hell even the power window regulator. Next time you hear it vibrating try to isolate what is making the noise by just putting light pressure on different areas of the door panel/door. Once you isolate what is rattling it is easy to fix it a number of ways.
I
Insayne
It's in the back. It's either the rear speaker sheet metal or the speaker cover or the foam hump trim piece that bolts in above the seats. I'll isolate it here in the next few days.
TheRainman
Mobile, AL
Dang, what you running 2 gauge wire for? I ran my 8 gauge wire behind the battery the windshield wiper fluid container into the fenderwell and through the side. There's a rubber stopper right by the door hinge that I cut, should be a big enough hole for 2 gauge.
