Project snowbunny
R
rtusnake
Lincoln, AL
Also mounted the steering column and wheel. Working on making the trim fit the column and blinker switch. Mounted shifter as well
R
rtusnake
Lincoln, AL
Made some covers for the steering column and also some tabs to mount the front end to the tube front. Also got a killer deal on some scales
R
rtusnake
Lincoln, AL
Set the motor and trans in to see how the headers fit and how I wanna do the intake. Also weighed the car as it sits now
R
rtusnake
Lincoln, AL
He said he wanted to have time to build his car and spend time with family. He has a nice build thread on yb going right now. 417 motorsports makes a nice tubular kit if you want to go that route later on
Staff member
300m input, stub shaft, sonnax forward drum, 300m direct drum, extra clutches in the foward and direct, and fb mvb
Dont forget the spiral snapring for the roller clutch. That thing will come off and wreak havoc. The sure cure kit has what you need in it.
