Jun 28, 2017 #161 lwarrior1016 Mr. Secondary Timing Chain Staff member Staff Joined Sep 22, 2014 Messages 9,306 Reaction score 5,722 Location South Mississippi rtusnake said: Put the cams and timing components back in tonight. Click to expand... Did you lock out the cams or are you still going to run the phasers?
Jun 29, 2017 #162 OP OP R rtusnake Member Joined Aug 6, 2013 Messages 140 Reaction score 0 Location Lincoln, AL lwarrior1016 said: Dont forget the spiral snapring for the roller clutch. That thing will come off and wreak havoc. The sure cure kit has what you need in it. Click to expand... It came with the rebuild kit bc automotive sent. Still running the phasers, the mmr plates are just lighter than the factory front plates
Jun 29, 2017 #163 OP OP R rtusnake Member Joined Aug 6, 2013 Messages 140 Reaction score 0 Location Lincoln, AL Starting reassembling the trans, waiting on a pressure plate to come in to install everything back in the case. Stock forward drum vs sonnax drum 300m input and foward drum together. Stock direct drum vs 300m center one Drilled pressure reliefs in forward and reverse piston for valvebody and transbrake.
Aug 21, 2017 #164 OP OP R rtusnake Member Joined Aug 6, 2013 Messages 140 Reaction score 0 Location Lincoln, AL Working on getting the pics back up for the rest of the thread but here is some progress. Took 22lbs out of the roof skin
Aug 21, 2017 #165 OP OP R rtusnake Member Joined Aug 6, 2013 Messages 140 Reaction score 0 Location Lincoln, AL Started ordering parts for the fuel system and getting it put in.
Aug 21, 2017 #166 96blak54 Moderator Staff member Staff Joined Feb 21, 2011 Messages 15,616 Reaction score 6,519 Location Lawrenceburg Kentucky Uhm....thats sum serious fuel supply! Sent from my SM-G900P using Tapatalk
Aug 24, 2017 #167 OP OP R rtusnake Member Joined Aug 6, 2013 Messages 140 Reaction score 0 Location Lincoln, AL Mounted the cell today. Still gotta make a couple more tabs to hold it in securely
