302N20
nope, don't have it, I have nothing but empty space behind there. I guess I have all the GT options except keyless, leather, and MACH 460
302N20 said:nope, don't have it, I have nothing but empty space behind there. I guess I have all the GT options except keyless, leather, and MACH 460
Traidmarx said:i just looked in mine..becuase i've never had a key fob for it since i've owned it..and back in the back the box is gone..the wire harnes is there but nothing in the little rack where it should be. I still have the original window sticker in from the car the previous owner kept it. and it did come with keyless entry so could i add the module and make it work?
Traidmarx said:so the box is actually behind that mounting bracket thing that says anti theft??
95_5.0@15 said:How do I jump a wire, do i just lay it out on the ground and jump over it? J/p BUt really how do i do it?
St33da said:scarface said:How do you find out if your car came with this from the factory?
Correct me if I am wrong, but I believe all GT's with the exception of the GTS came with it. Remove the pannel in your trunk like you are going to access your tail lights, then on the drivers side you should see a small box that says anti-theft on it. If you see that, then your car has it.
T-5 Killer said:St33da said:scarface said:How do you find out if your car came with this from the factory?
Did all the Cobras come with this?
