Exactly right. It’s an alternator misalignment. Apparently some alternators have different pullies. I just recently got the right one.
Oh yeah, I forget about that.
Has to be a truck block thing.
I should, but I’m cheap. I’m going to slam another piston in it and see how it goes. If it doesn’t work out, it might get a little wild. High compression and some spray.Would be sad seeing this car LS swapped but cheap fun atleast. I know you like high compression builds. You should do a gen2 high compression setup.... now that would be spicy.
I call broken coyote parts
That's Coyote parts?New piston, rings, and bearings. Waiting for the head gasket, oil pan, and head cooling mod to get here. View attachment 7822
Yes sir.That's Coyote parts?
I broke a piston lol. If you scroll back just a little bit, I showed pictures.i guess i'm in the dark, but did your bottom end come apart or is this a new build?
Oil pan gasket?
I really don’t think is tune related. I think it was detonation, but I feel that it was caused by the extra heat built up in that cylinder due to coolant flow issues. I always run 93 in it.Looks like some tuning adjustments are in your future. Are you just running premium pump gas?
