Got this for 300. Owner didnt know anything about it, bought it from "estate" sale. Had no keys, was completely loaded with junk and had algae growing on it. On the tow home found out, tranny and rearend was locked up. Rear end was rusty from what i could see.
Now forward to today..
Runs and stays running. Revs and moves a few feet at least.
Transmission works
Rearend is free and moving
Breaks work
Got new seat of key for ignition and door locks. Still need trunk lock.
Cleaned and steam cleaned interior
Taped off the radio headunit wiring until i can fix it from the hackjob it was.
Bad...
Trunk rust
Underbody rust
Frame rails rust
Doing wire brush to it, and then sand it all out. Next ill por15 the whole underbody and the interior up to the rear seats for sure. Thinking of doing everything at some point.
Replaced fuel filter thinking it was leaking but its actucally coming from right above it on the fuel tank to filter line?? I'm not for sure yet, dropping gastank now. Ill upload pics soon.:headbang:
White 99 v6 5spd time!:headbang:
Low speed impact in the passenger headlight area. Whole core support and aprons needs replaced. Have one headlight and drivers fender still in good shape. Engine, and radiator are still good. K-member might not be.
Has some mods!
8.8 rear and some shocks? Im not sure?
Ill post more as i go
Barely any rust underside and low miles. I can use everything off this car.
Transmission works
Breaks work
Bad...
Trunk rust
Underbody rust
Frame rails rust
Has some mods!
