starter selenoid starter wire?
Where does the starter wire go that feeds into the selenoid? I am trying to trace it and unfortunatly do not have a lift and can't see where it is going.....
Father Guido
Just modified mine, it runs forward from the starter, around the front of the engine under the harmonic balancer and up to a connector just behind your battery. From there it goes to the fuse block, hope this helps.
I finally figured out that the relay was in the under-hood fuse block and got it. Thanks for the help.
