Re: The SBF 306 Engine Build - Updated 02/14
I have really been working hard to make progress this week. Every night after work I've been spending a few hours in the garage working on stuff.
Tonight I bead blasted the accessory brackets that I smoothed out last night. They're not perfect, but it's the best I could do with a somewhat pitted Ford casting and limited tools.
Then I spent about two hours powdercoating everything. It's gunmetal gray just like the timing cover. Here's the finished product.
Also, while I waiting for some parts to pre-heat in the oven, I saw my throttle body sitting on the shelf. You know that weird brass tube that sticks out of the top? Well, as I've done on previous cars, I deleted it. This is ultra simple and takes about ten minutes.
First, grap a 1/8" NPT tap, and clamp the TB in a vice. Then tap the threads carefully, making sure to use some WD40. Don't He-Man the thing. Go slowly and use some compressed air to clean out the shavings every couple turns to ensure you don't gall up the threads with crap.
Here's what it looks like when you're done. Good enough for the girls we go with.
Then grab a 1/8" NPT pipe plug and screw it in. You're done.
That's all for now. More to come. I need to order some more gunmetal gray powder - I'm running low.
Paul.
Paul.
