Trick Flow Intake Q?
det_riot
Dearborn
I found a deal on a Trick Flow upper and lower on craigslist and was wondering what you guys would think would be a fair price for it? It's the trick flow street heat upper and lower with the sn95 elbow included. His ad says there's only been 10 track passes on it. I really wanna pick this up but don't wanna get screwed over on price. Thanks for the help!
19fobra95
well im selling mine for $350 but i made the price a little high just because of all the low-ballers around hear. My buddy picked one up for $275. i'd say anywhere around $300-350 or so would be fair with the elbow.
det_riot
det_riot
Dearborn
alright sweet sweet. so offering 250 wouldn't be a huge low ball starting point
mikey94gt
Sounds good to me, offer him $250 and go up to about $350, make sure its nice too. dont forget the hardware, you cant use the stock stuff, btw. it should come with some barbed hose fittings too.
det_riot
det_riot
Dearborn
The hose fittings on the underside correct? How much is the gasket set for it?
det_riot
det_riot
Dearborn
Whoot! Picked up the upper/lower with the elbow and gaskets for upper to lower and elbow yesterday! Since we're getting snow tuesday, this won't project won't be started until it starts to get warmer =[. But in the meantime is there anything else that I'll need to do the swap? I've looked at the how to and I'm a little confused on a few things.
1. Will I need a new gasket from the heads to the lower? This isn't anything that needs to be special ordered correct?
2. How much of a restriction will the stock t/b be? Anything that needs to be worried about now or should I hold off on getting a new one until I get some new heads? If/when I do get a bigger one, is a bigger MAF necessary as well?
mikey94gt
YOu will need head to intake gaskets, just call summit and tell then what your doing, they will set you up. I would grab a PCV valve and some vacuum hose while your at it.
I would keep the stock TB for now, and swap it later, its not a big deal, but will improve your perfomance later.
You dont have to get a MAF, but the stock one is a pretty big restriction. I just sold a 73mm C&L with 19# and 24# injector tunes too.... I have another that I will sell shortly, its in use now.
Overall, I would change one thing at a time so you know what part effected what, then its easier to track down problems.
