Unique build.
lwarrior1016
Mr. Secondary Timing Chain
Staff member
South Mississippi
Stock for now. I'll rebuild the damaged no oil pressure motor one day. Just. No interest in that right now.
Man, you don't want to rebuild that thing. Too much headache. You should just pass those 278's off to me so you don't have to deal with them anymore lol
Wichers123
Wichers123
Covington, louisiana
I have the whole package I'll sell to anyone for 600. That's cams (they need some hand polishing), cloyes hex a adjust gears, btr springs, retainers, cms modified valves.
Wichers123
Wichers123
Actually they are to big for stock the heads should have to be pulled and fly cut the Pistons. I just don't want to do that. Not right now. The stock bottom will only be able to handle 450ish so puting cams in it would just not benefit as the hp cap is so low. I beleive the built motor was 650ish at 17psi and 13 degrees of timing. The car just never had a chance to be turnt up... Lol
Wichers123
Wichers123
The direction I'm going this time is straight street terror. 10psi should make traction a mother and the 5speed will just rip. The car I think accelerates much harder with 5speed cause the auto had no real load as the torque converter ate up all of it.
Wichers123
Wichers123
Well today was a pita but I got the job done. All I need is to button up the last few bolts and install toe arms. Then the next project is splitting the trans to install billet shift forks.
Mrstangerbanger
CHICO , California, United States
Woot I got injectors, programmer, fuel pump, maf, air filter in getting much closer..
You will love that pump there quite and i have a 280 amp alt so my voltage in my car is always in the 14.4 volt range so my pump works amazing and is holding up great so far but then again i put some stinger sound deadening under the gas tank just in case the pump was loud but its not at all. Great pumps. Are you running a return less or did you covert to a return style system? Sick car and build keep up the great work love it.
Wichers123
Wichers123
Mrstangerbanger... Lol i painted that with vht wrinkle and it later started to flake off. The pump has since been changed to a aem e85 safe unit, in my area we have a lot of mixed fuel. And I have since changed from those injectors too. Now running 60's
