vtchopperdude
- Joined
- Feb 7, 2021
- Messages
- 222
- Reaction score
- 242
Installed DriveWorks greaseable lower ball joints and outer tie rods. Hopefully that'll eliminate the front end clunk. The ball joints had significant play in them...
looks a little daunting to me. never messed with the internals on a trans.
It's all good until you realise you've missed one...
TMW
EDIT - Congrats on the 1,000th post!
you are braver than I am to get youtube tranny certified.That's what I thought as well, but I went over a few Transmission Bench youtube vids, and bought the 4R70W transmission repair manual so It's not as bad as I think it will be. Ill be playing those Vids while putting it together they're very detailed as well as the manual.
As long as I have no parts left over, I should be good...
Have same problem haven't found it yet?Well, still have the front end clunk. The front sway bar bushings look ok. Maybe shock mounts? Or bad shocks themselves? Not sure at this point, and I don't want to go throwing money at it if I can help it. I'll check to see if the sway bar bushing bolts are loose (the bushings themselves look ok), but it sounds more prominent on the passenger front. Not as pronounced on the drivers side...
All I did was expand your horizon. You’re welcome.Lol, I'm mechanically inclined so hopefully no problem... If there is I'll blame @lwarrior1016 for telling me it's not has hard as it looks...
did you replace the fuel filler gasket also? The one around the pipe on the side of the tank? They tend to tear moving it around much and cause a leak.
If it is torn it will not leak until the level is high enough or if you take a turn hard enough and it sloshes. You will know if there is a leak just follow your nose. Hopefully your safeI did not... I didn't even think about that when doing the job to be honest, but the gasket looked to be ok. I think that's the first time the tank has been dropped, so everything was intact.
its only money why not do both?Realized that with the money I’ve spent on guns recently I could’ve had the car painted while the engine was out.
