cobrajeff96
I am serious.
I am getting it put back together. And stop calling me Shirley!! Lol
Sounds like Mick Jaguar on ludes!I found your song
Quick qestinsNice one. How does it fit? I bought a passenger side cup from CJ (repro) because the stock had broken tabs. It looks nice, but the front part (towards the dash) does move a bit when pulling the door, although all the tabs are in their place. I don't know what I could do about it.
Quick Question: What adhesive did you use to set the door handle cup?Nice one. How does it fit? I bought a passenger side cup from CJ (repro) because the stock had broken tabs. It looks nice, but the front part (towards the dash) does move a bit when pulling the door, although all the tabs are in their place. I don't know what I could do about it.
i would be changing a heater core at that pointFinally got around to swapping the new dash into the 01 since after I swapped the fuse box, it would crank but wouldn’t start. Might as well swap everything over. I got the dash in and started plugging the connectors in when I found one doesn’t fit. All the other connectors are the same but one isn’t and it has a different number of pins so I’ll have to do some research. One step forward, two steps back.
View attachment 49846View attachment 49847View attachment 49848
And what is that next to the gas pedal in the last pic?
I was going to buy it looks like it’s at least newer. I’m not going to tinker with it and screw something else up lol.i would be changing a heater core at that point
thinking ahead
I’m sure you’re right, though it was cut. And when I put the new fuse box in the brake lights were stuck on even with the fuse out and the sensor unplugged. That was the point I threw in the towel and decided to just go ahead and swap the dash, which I already had.Well, it's actually common for the brake light switch wiring to get chafed against the armature in a SN95's manual pedal box. Happened to my car many years ago and I had to relocate that branch of the harness slightly and overtape it. I kept wondering why my brake light fuse kept popping one night, I'd press the brake pedal and saw no red light behind me.
Whatever you do, make sure you have a new fresh can of smoke, in case you lose some. Hopefully, you won't need to use it.I was going to buy it looks like it’s at least newer. I’m not going to tinker with it and screw something else up lol.
I was originally going to depin and repin the one connector that isn’t the same but it seems to be molded together so the pins won’t slip out. I cut the connectors and am in the process of splicing them together. I verified the wire colors are the same and the circuits on them are the same as well. With this done, I’m going to plug everything in and mock it up and see if it starts. Fingers crossed.
I hate wire nuts. It’s like are you that lazy you can’t even be bothered to use butt connectors. Geez.Whatever you do, make sure you have a new fresh can of smoke, in case you lose some. Hopefully, you won't need to use it.The best part of your thread is the "wire nuts". OMG, I've seen that so many times it makes my skin crawl.
I am afraid to know the answer but too curious to not ask, how much are you guys paying for gas now? I apologize that our "president" caused it, please forgive us....I did a quick polish of the car and applied weatherproofing on the convertible top. Then drove with my son to the station to fill up the tank and buy ice creams.
View attachment 49874View attachment 49875
