what setting to start at
brian95
indiana
went to track and couldn't get better than a 1.8 60 ft. first time out since changed everything. what would be a good starting point to go with.
this is what I have
all UPR front
k member with ADJ A ARMS
strange 10 way struts with coil overs ( will check which size spring)
flaming river manual rack
25x4 weld r/t skinny,s
caster camber plates
proper bumpsteer kit
back
ADJ lower control arms
double ADJ uppers
strange 10 way shocks with coil overs.
26x10 weld RT/S with M/T slicks
8.8 with 31 spline axles
Musturd
Turn them both all to left softest setting possible and what you launching at I got better then that in a stock car with just 26x11.50et streets
Wichers123
Covington, louisiana
Do not set them shocks to the lowest settings, set them at 3 at first in the rear and change the fronts to 5. I would start there first.
Musturd
Lol 5 ain't good enough for the front ... I know, I'm running them in my car... Fronts are on 1 rears are on 5 . You want the fronts super soft so the front end lifts up and gets weight transfer I don't know if you understand what that is .... You sure as hell Won't get any weight transfer with the fronts on 5
Addermk2
Oh yeah then explain how I was cutting 1.9 and 2.0 60fts on a unprepared track.
Um. 2.0 is a shit 60'. I did 2.0's on stock suspension and street tires.
OP. 1 in the front, 5 in the rear. Then test from there.
Also, your rear suspension geometry is crucial.
Musturd
With proper setup you and a little burnout you can dead hook on the street... Vids to be posted this weekend of street car having fun. The front ain't so low anymore.... Seriously though not trying to be a super dick but that's 60ft's embarrassing if you have any sort of drag suspension .... If you've seen how big no prep racing is down south you can make that ***** work like nothing .
duff daddy
Wow, this is an amazing tech thread with some good dick measuring.... dontforget most big power small tire cars that do amazing things on the street (IE boostedgt) Have the added benefit of of a boost controller....
but yea 2.0 sucks donkey balls
As you were.
Musturd
This is with stock 4.6 NPi lt's and 373's. stock cut springs and strange 10ways front and rear.
My stock npi 4.6 with stock shocks and control arms on et streets would do 1.7 60fts I'm not knocking ur skills .
Musturd
As you were.
I hear that man if I bottle launch on the street even my et streets will blow off .
Musturd
Et streets are drags?
Bias et streets I don't mess with drags they are kinda over kill... I used to use stock 16" 94 gt wheels here's the setup I used to run
