which intake will give me the best results
i_love_my_stang
doing a 331 stroker
75mm tb, cai, prob going with 32lb injectors. 5 speed, 4.10 gears
probe pistons
http://www.probeindustries.com/ProductDetails.asp?ProductCode=10666&Show=TechSpecs
world products windsor sr. heads
http://www.worldcastings.com/products/windsor-sr-iron-heads.html
probably just going to do an out of the box cam from comp
http://www.compperformancegroupstores.com/store/merchant.mvc?Screen=PROD&Store_Code=CC&Product_Code=35-775-8&Category_Code=F50COMP
which intake should i go with, i was thinking either the trick flow track or R, or maybe the holley only thing up here holley is about double the price and if its only a couple hp difference i dont really see the point?
5.0kid
I'd probably go with the tfs track heat or R, depending on the rpm range you're wanting. Not worth the double price difference between the holley and trickflows.
ohno50h
Go with the track heat or the 75mm version of the r intake simply because whats the point of the 90mm throttle opening when your only running a 75mm tb. also whats the price for the holly where you are?. i know prices are brutal here in canada but check out themustangshop.ca because their prices are really good and they are great to deal with. i personally would want to use the holley or performer rpm 2 since both are proven to work well.
