Well, I might tend to agree but we were stopping at a red light...
just saw your build thread. car looks sick!!!!!!! love it. you running dumps or are you going to run the pipes out of the back? nice job!!!!!!!!
You are technically in the South so stacks would work.
You still got the stock fuel pump and injectors in there?
Unplug the maf then drive. This wont solve any issues but will open the door to diagnosing process. The car goes into a safe mode when the maf isnt connected by fattening up the mixture. If you do this and are amazed, youll need to either get a tune or maf sensor. ..or both....but lets hope not
When it breaks up in the high rpm is it only when your going a high rate of speed? I say this because I had the same problem that drove me absolutely nuts on my 98. Turns out that only in 98 mustangs had an "awesome" feature that cut spark when you reached a certain top speed. Since I have gears on my car my speedo is off quite a bit which reached the top speed limiter and had the high rpm sputter/breakup condition. Make sure your tuner has the top speed limiter turned off.... Video of my condition before I found out what the problem was.....
:17 second mark...
[video=youtube;nqjkYDkN_Vg]https://www.youtube.com/watch?v=nqjkYDkN_Vg[/video]
