White's '98 GT "Spaceghost"
IRS catback? For this car or your other car? Where is the IRS going? I iz confused.
white95
white95
Apex Junky
Prairieville, LA
Now that I have two of them I'm not sure either!!! On one hand I can continue preparing the IRS war or keep it as-is and use it for my daily driver.
Why irs? Is this a better solution than straight? Ive thought irs just because I believe it looks dope!
Fast around corners? My main purpose is build, looks, and street. If the irs helps it hook, im for it!
white95
white95
Apex Junky
Prairieville, LA
IRS offers better ride quality and better handling if you like finesse. The solid axles are the better choice for big power, drag racing, clutch-drop-shenanigans and you can slam power down leaving a corner, well, if it's setup properly with a watts link/TA or watts/PM3L combo.
white95
white95
Apex Junky
Prairieville, LA
While filling my car up I noticed it was nearing 12 gallons and wasn't slowing. Before I could react, it started leaking into the ground. It's now obvious my leak wasn't the filler neck grommet after all. Hell, it couldn't be that easy right??
At home:
I jacked it up, put her on jackstands and the top of the tank was wet. Seems to be leaking from the pump hat.
Great... Guess I'll be dropping the tank for a further inspection.
white95
white95
Apex Junky
Prairieville, LA
Smart you backed up to the drainage basin that the gators live in. No body no crime!
ElrodKTPQ_89
Crossett, AR
I'm gonna be that guy to hate on the fender hash marks. I think they would look a lot better if the car was lowered and had tinted windows or at least some other black accent though. It can be pulled off!
peasant99
