1995 mustang build up :D
1994stangfan
1994stangfan
Ontario canada
Did a Bunch of little stiff today
-installed the egr
-routed and connected the remaining vacuum lines
-re-routed the alternator wires and installed new wire loom
-painted a bunch of random bolt heads
-cleaned the battery tray
-ordered a new belt
Cleaned and painted the distributor and hold down
-POLISHED THE SUPERCHARGER
1994stangfan
1994stangfan
Ontario canada
Made a coil relocation bracket out of aluminum today. Have to take it off and polish it now that I have it fitting the way I like.
1994stangfan
1994stangfan
Ontario canada
Finally making progress. Got the mishimoto rad out of the box, installed the mounting brackets and put it in the car.
Got the proper length serpentine belt and installed it.
Finished up a lot of the wiring and connectors under the hood.
Removed the computer to install the moates quarter horse.
Installed the battery tray and battery (until I can afford to relocate it)
1994stangfan
1994stangfan
Ontario canada
Installed the moates quarterhorse today
Also installed the 255 lph fuel pump
1994stangfan
1994stangfan
Ontario canada
Well the car first up today, ran like a champ. I let it run for about 10 minutes shut it down and now it won’t fire. Turn over but won’t start. I’m perplexed
evilcw311
Most Evil Member!
Louisville, KY
Run out of gas already?
Old dizzy?
Is fuel pump still priming?
1994stangfan
1994stangfan
Ontario canada
Old dizzy?
I out 10 gallons of fuel in it, the distributor is my old one, fuel pump is priming and running.
I just got the car to fire, had to give it throttle. It’s started but the idle is surging
evilcw311
Most Evil Member!
Louisville, KY
Needs the tune. Ecm isn’t liking all the changes it sounds like
evilcw311
Most Evil Member!
Louisville, KY
Check iac. May be sticking or not working properly. Could also be a vacuum line that came loose. Both of those would cause the same thing.
1994stangfan
1994stangfan
Ontario canada
Awesome that’s for the tips. It is a different iac than I used before so it could easily be the issue
1994stangfan
1994stangfan
Ontario canada
Also I just adjusted the timing a little bit and now she starts without throttle and runs much smoother. I can locate the spout connector so I haven’t set the timing yet. I have looked in the passenger fender and can’t locate it
evilcw311
Most Evil Member!
Louisville, KY
Yeah timing is kind of important too. Lol
1994stangfan
1994stangfan
Ontario canada
Here is the video of the first start
<div style="width:100%;height:0px;position:relative;padding-bottom:100.000%;"><iframe src="https://streamable.com/s/ap3i7/mzuedw" frameborder="0" width="100%" height="100%" allowfullscreen style="width:100%;height:100%;position:absolute;left:0px;top:0px;overflow:hidden;"></iframe></div>
evilcw311
Most Evil Member!
Louisville, KY
That is very odd. It doesn’t sound like it hesitated or had a miss due to timing being off. You’d think it wouldn’t of started that smooth otherwise.
Carolinastang78
