Rolltide1006
- Joined
- Mar 22, 2014
- Messages
- 132
- Reaction score
- 3
Gotta get these things ready too. Need to let them soak in oil
Sent from my iPhone using Tapatalk Pro
Dang, looks good!
Id be willing to bet it smells great too!.....
Dont forget the timing wheel
Sent from my SM-G900P using Tapatalk
Loosen the cams and lay all the followers in place, the tighten the cam down all the way across the head evenly. Or, compress the oil out of the lash adjusters.
That'll work. With the crank key at 9 the timing dot is close to 6 so keep your cams close to where they time and you won't have to move them much.
Well, how did the weekend turn out for you?
Hey Warrior, it went well [emoji1303] but with the motor... I put my crank at 9 oclock but my cams aren't where you said they be so I held off.
That's with my crank at 9 o'clock
I thought I remember the crank dot being closer to 6 with key at 9. Either way, your crank dot is close to 6. Roll the engine till the crank dot is at 6 and double check your alignment. You should be good to go though, your timing looks correct. After double checked, roll the engine a bunch of times by hand and make sure you dont have and piston to valve contact.
All timed up!
How you have it timed right here is what I am referring to.
sorry man totally forgot to respond to your message. I don't see anything wrong with how you did it, timing looks on.
