94Droptops Build Thread Heat Extractor on and Painted.
uncltrvlnmatt
Pa.
Re: 94Droptops Build Thread
You have an oil leak from your door!!!! j/k
Looks good, be nice to see it run.
94 DropTop
Well havent been on in awhile. I have since bought a zex wet kit that will be going on soon. Other than that i have Stripped out a spark plug so while retapping that i desided to do a little painting and cleaning while I was there. next mods will be a fuel pump and a battery relocation. I have also desided I dont like there bottle in the passenger spot so it will be moving to the trunk also.
MustangChris
Aurora, CO
you need more chrome.... ... chrome adds HP....
nice build man... :) hope to see it done soon... update us more often, will ya!??!?!
BruhBrahBrad
Hey if you dont like the white top, I have a friend who painted his top with the duplicolor vinyl dye, the same stuff I used on my interior and it looks good. It has survived a few good hard rains. Still looks good. I think your car would look tities if the top was black.
94 DropTop
I have thought about doing that. What process did he use to do it? My car sits outside all the time. Im not sure if I have the balls to do somthing like that.
BruhBrahBrad
I think he just cleaned it,taped off the car and sprayed.
BruhBrahBrad
Nah I dont see him often but it looks just like a stock black top.
94 DropTop
Well I just purchased my Battery Relocation kit from UPR and my 255 pump from JD's Performance. Now i can finish my nitrous install, and I think ill go ahead and yank the power steering when it warms up.
94turbostang
if i were you id remove your smog pump too and get a block off plate for it, its pretty useless anyways. and if i could recommend one thing itd be to swap the stock heads for aftermarket ones. the heads on stock mustangs flow like complete crap. im doing a low compression build and the compression is under 8.4 now and is still faster now un boosted and on low compression than it was when it was at a higher compression with stock heads. a cam and heads would get you farther than youd think. if you willing and have the cash, id recommend some afr heads or trickflow twisted wedge heads
nice work! the black wheels and IM looks great.
agree with dying the top black, would look bedda!
94 DropTop
Thanks Dal. ive been thinking about it but cant deside if I want to chance fucking it up.
And turbo my smog system is already removed. I will get heads after i get some tires and a converter. I I want to see how far this stock engine will get me. I havent desided what I want in an engine key to why I have the nitrous. Ill get heads when I blow up this motor.
94 DropTop
Well I found a deal on some heads go I got them. So far I have Some ported E7 heads, E303 cam, Crane 1.7 RR, Hardened pushrods that came with the heads hopefully I will be able to use them. UPR battery relocation,taylor battery disconnect, 255 fuel pump, and some seat extenders. And now for the pics.
droptopstang13
brad94GT
nice man ill have to come see this car in person some time maybe race ya at the track or something
94 DropTop
Sounds good to me. Ill still be slow.LOL Just sent the heads out today for a valve job and to be resurfaced.
94 DropTop
Well i purchased the UPR torque box reinforcement kit, ashtray switch panel, and a Dyno Tune bottle heater. Once I get my heads and seat brackets back from the machine shop im going to take my car to a local shop who is going to install the torque boxes, and make me some subframe connectors. Pics hopfully in the next week or two.
330CubeGt
Looking good, you like the wheels better now?
got5.0
Atlantis
this is a cool build. I love budget builds cause they're simple but usually very effective. Keep us posted and get to the track!
96GTPlanB
